Zantus
Posts: 137 Joined: 30 Apr 2009 14:50
Full Name: Barto de Koning
Nickname: Zantus
Home Town: Port Elizabeth
Has thanked: 3 times
Been thanked: 5 times
Post
by Zantus » 21 Jul 2013 23:17
Anyone have an exploded view/diagram of a GU rear axle they can post....please
My rear diff-lock is occasionally releasing with a bang since I got and I suspect damage similar to the pics posted in this post:
http://www.patrol4x4.co.za/viewtopic.ph ... 777#p41377
After sorting the gears out I will give the vacuum system some attention as well, as that might be the real reason why the damage happened in the first place.
Posts: 6157 Joined: 10 Sep 2010 07:21
Has thanked: 1134 times
Been thanked: 1044 times
Post
by Peter Connan » 22 Jul 2013 06:44
Zantus send me a mail at petercatmitechdotcodotza?
David
Posts: 723 Joined: 17 Dec 2009 12:42
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Has thanked: 2 times
Been thanked: 49 times
Post
by David » 22 Jul 2013 09:02
Hope this helps...
David
Nickname: David
Post
by David » 22 Jul 2013 09:08
If you ever come my way I will give you a copy of the electronic service manual
Zantus
Nickname: Zantus
Post
by Zantus » 22 Jul 2013 09:38
Thank You!
I'm also looking for the complete rear axle drawing, basically need to see how to remove the shafts to get the third member out.
David
Nickname: David
Post
by David » 22 Jul 2013 11:37
Zantus, I will have a look but I think it is time you get the electronic manual
Zipped it is about 140Mb - Any way I can get it to you?
There is a whole chapter on the diff and another on the axle. PM me your postal address and I will post it to you
Zantus
Nickname: Zantus
Post
by Zantus » 22 Jul 2013 16:15
You could upload it to something like mediafire or dropbox?
David
Nickname: David
Post
by David » 23 Jul 2013 07:22
Tried Mediafire and they tell me my email is already in use??
Dropbox is blocked from work
If you create a Mediafire account I will upload it there...
David
Nickname: David
Post
by David » 23 Jul 2013 14:52
Post
by Peter Connan » 23 Jul 2013 17:14
Barto, had a look at the clip you sent me, and I suspect that you are unfortunately correct.
