1999 GU Y61 mags
Tiny Howarth
Full Name: Graham Howarth
Nickname: Tiny
Home Town: Walvis Bay
Has thanked: 31 times
Been thanked: 25 times
1999 GU Y61 mags
Post by Tiny Howarth »
Any aluminum mag rim suppliers I can contact for mags cannot find in Namibia with a 110mm centre bore, plenty of mags here only 108 centre bore
Has thanked: 246 times
Re: 1999 GU Y61 mags
mvcoller
Full Name: Malcolm van Coller
Nickname: mvcoller
1998 4.5 Patrol SGL
Home Language: Afr & Eng
Has thanked: 41 times
Been thanked: 187 times
Post by mvcoller »
I have three times before had the centres of the normal 6 x 140 mags opened up from 108mm to 110 mm. Just recently I had 17" Ford steel rims opened up to 110mm for my trailer so I could in emergencies share wheels between the trailer and my Patrol.
Any engineering works worth their salt could successfully do this.
I took the Ford rims to an engineering shop that in the 70s and 80 widened steel wheels for me. It cost me R180 to open the centre's of the three steel wheels.
Tiny Howarth
Nickname: Tiny
Hi sent errols tyres a email a month ago still no reply
Tiny Howarth
Nickname: Tiny
I was told by A-line mag manufacturers that it is not safe to machine the bore out.
Has thanked: 1135 times
Been thanked: 1046 times
Tiny Howarth wrote: 28 Nov 2022 22:36 I was told by A-line mag manufacturers that it is not safe to machine the bore out.
I can't see how a mag made with a 110mm center is stronger thsn one made with a 108mm center machined out to 110mm?
I think they are just covering their butts.
Certainly, the A-line wheels I had machined gave me 10 years of trouble-free service.
IanT
Full Name: Ian Temperley
2008 4.8 GRX Umkombe
Post by IanT »
I have a set (5) Black Rhino Mags growing dust on a rack (patrol spec)
IanT
Post by IanT »
I have a set (5) Black Rhino Mags growing dust on a rack (patrol spec) 17 inch
mvcoller
Nickname: mvcoller
1998 4.5 Patrol SGL
Post by mvcoller »
They told you a load of hogwash.
If standard Patrol mags are made with a centre bore of 110mm and the PCD is 139.4 or if you take a same or similar mag make that has a centre bore of 108 PCD and enlarge the CB from 108mm to 110mm, what is the difference between the two final products? Both the original one and the modified one will have 29,4mm of metal between the stud hole's centre point and the edge of the Centre Bore, if the material is the same metal, the same thickness and presumably the same tensile strength?
I had many, many sets of mags modified for racing and raced them like that for many years, never ever had a problem. The issue is to ensure you use a reputable crowd.
I used the late Cedric Saffy (of Mag Wheel Services in Mayfair Jhb) and Tony Domingo ex SA Formula one driver when SA still had the only National F1 series.
I had mags widened, offsets changed, PCDs changed, number of wheel stud holes changed, centre bores changed, you name it, I had it done and I never ever had any issues.
