Td42 gearbox noise
Vatikaki
Full Name: Paul Bester
Nickname: Vatikaki
Home Town: Cape Town
Current 4x4: 2007 TD42 N/A Pickup
Home Language: English\Afrikaans
Has thanked: 9 times
Been thanked: 4 times
Td42 gearbox noise
Post by Vatikaki »
Hi Chaps
I picked up my first TD42 pickup today. I have a clutch/gearbox question. When in neutral and idling there is a alight grumbling/grinding noise. Once I press the clutch in it dissapears. The clutch is very easy to press in. Any ideas?
Paul
Dungbeetle
Full Name: Rudolf
Nickname: Dungbeetle
Home Town: Ellisras
Home Language: Afr
Been thanked: 69 times
Re: Td42 gearbox noise
Post by Dungbeetle »
My TD42 has been doing that for 600 000 of its 849 000 km
2012 NP300 DC - platkar
martyn
Full Name: Charles Fry
Nickname: Charlie
Home Town: Robertson
Current 4x4: Patrol 4.5
Has thanked: 83 times
Been thanked: 41 times
Post by martyn »
Sounds like the thrust bearing.
Diem Dulcem Habes
Have a good day
The td42 has a harmonic sound that does that let frans have a look but normally not a problem
Pieter B
Full Name: Pieter Botha
Nickname: Pieter
Been thanked: 97 times
Post by Pieter B »
Probably just the thrust bearing. In what condition is the clutch fork rubber?
This is a known issue on the TD42. It is a harmonic vibration in the clutch or pressure plate.
It does not indicate impending doom in any way.
Been thanked: 430 times
Believe it or not, but it is actually the springs on the clutch plate that "rattles" as Peter mentioned. If you would to change the clutch, the noise will be gone.
I have done many many clutches on the TD42 and this is the problem. The Nissan clutches seem the ve "rattle free" for much longer than the Valeo or other brands.
Its not the release beaeing. If it was the release bearing it would make a noise when the clutch is depressed
