Torque curves
- Has thanked: 1141 times
- Been thanked: 1049 times
Torque curves
Does anybody know where i can get torque curves for the various engines? Preferably un-modified engines, and ideally also going down to fairly low revs.
- Has thanked: 62 times
- Been thanked: 257 times
- Been thanked: 432 times
Re: Torque curves
Ja Peter dit gaan moeilik wees om so iets te kry. Dyno dag gaan die enigste way wees.
Ek het standaard TD42 curves, maar als begin eers op 1,500rpm.
Vir een of ander rede dyno almal eers vanaf 1,500rpm af
Re: Torque curves
Michael, dis 'n beginpunt. Kan jy vir my een stuur asseblief?
Re: Torque curves
Peter, al wat ek huidiglik kan kry is n kombenasie van n NA dyno grafiek met n ander voertuig se krag bo hom.
Die blou lyn is n NA TD42
- Nickname: mvcoller
- Has thanked: 41 times
- Been thanked: 187 times
Re: Torque curves
Hi Peter,
Unfortunately my figures are not for an unmodified Patrol.
Herewith my 3.0Di (2008) pre CRDi motor's torque figures as at Jan 2018.
75mm exhaust,
300 x 600 front mount intercooler,
Madman,
SAC Chip
(at that stage with 265/70 x 17 tyres - 32's) - Tyre size makes a huge difference on torque figures.
This was after new injectors were fitted in November and a turbo recon done in April 2017.
After the above mods, these are my torque figures
RPM - BEFORE - AFTER
1500 - 192.3 - 306.3 NM
2000 - 293.2 - 362.0 NM
2500 - 277.0 - 342.7 NM
3000 - 245.8 - 300.3 NM
3500 - 235.0 - 267.7 NM
4000 - 185.3 - 205.8 NM
75mm exhaust,
Madman,
SAC Chip
Re: Torque curves
Pretty impressive Malcolm. Are those corrected for friction (ie estimated flywheel figures)?
