Need advice please
Andre
Full Name: Andre Visser
Nickname: Andre
Home Town: Richards Bay
Current 4x4: 1995 Nissan Patrol 4.2 SGL
Need advice please
Post by Andre »
I took my 1995 Patrol 4.2 SGL for a service. The workshop reported that the HT Leads need to be replaced but Nissan cannot supply them due to the age of the vehicle. Can anyone advise please: 1. How serious is this problem 2. Where can I get HT Leads
I am an accountant with little to no knowledge of this kind of thing... therefore asking those that know.
Been thanked: 724 times
Re: Need advice please
I assume the HT leads are the HT leads for the spark plugs ?
If so, any decent spares place should be able to provide them. Think the biggest issue might be length (normal HT leads might be too short), but any decent autoelectrician should be able to make up a custom set for you without any difficulty...
:mytwocents: :mytwocents:
Ian
Andre
Nickname: Andre
Post by Andre »
Thanks Ian, yes it is the HT leads for the spark plugs.
Andre,
No big deal replacing them aftermarket then. Chat with your local spares place (Midas) and see whether they can help you. If they do not have cables long enough, go and see a auto-electrician. It will also be a lot cheaper than working through the dealers.
Finally, if the HT leads are on the way out, it is a good idea to have them replaced in any case - otherwise you may have misfiring and similar.
Hoop jy kom reg.
Ian
Andre
Nickname: Andre
Post by Andre »
Gaan so maak Ian, dankie.
Has thanked: 189 times
Been thanked: 270 times
If you don't come right, see if David can send/mail you a second hand set....
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
Post by AndriesS »
Most Midas and Autozone have kits fro various cars, let them start by bringing a you Skyine 2.8 set, they are fairly long- check the distribute side connection and length against yours, else they should have loose ones and you can make up a set from that . Bougi Cord is the most common brand.
David M
Full Name: David Marais
Nickname: David Marais
Home Town: Midrand
Has thanked: 20 times
Been thanked: 97 times
Post by David M »
I was able to get a set for the 4.5 from Motozone in Midrand when no one else including Nissan had. Still going strong 2 1/2 yrs later. Nissan can get but will be ex Japan at between R 1 500 to R 2 000 and up to 21 working days. Your dealer (stealer) is just too lazy to order. Motozone was about R 600 for Bougi Cord. If you want original Nissan speak to Shaun at Mark White Nissan in Fourways. Both Motozone or Mark White will courier to you.
Andre
Nickname: Andre
Post by Andre »
Local spare shops in Richards Bay cannot (don't want) to help. Thanks for all the advice, will take it up. Wonderful reaction from you guys.
David M
Home Town: Midrand
Post by David M »
Andre - If you pm me your VIN no I will check with Shaun at Mark White. Just maybe it is one of the parts that is reasonably priced.
