Auber ETG Gauge
PaulvdMerwe
Full Name: Paul van der Merwe
Nickname: Paul
Home Town: Graaff Reinet
Current 4x4: 2001 Patrol 3.0 DI GRX
Been thanked: 6 times
Auber ETG Gauge
Post by PaulvdMerwe »
Hi,
So, julle sal onthou dat ek my ZD30 oorgedoen het.
So het ek ook genoem dat ek nie gate wil maak om EGT en Boost Gauges te fit nie, so ek het maar die Ausies se raad gevolg en besluit op die Auber Digitale gauges.
So vandag het die pakkie gekom, so raai wat doen ek die naweek?????
Ek het reeds toe die enjin nog uit was die manifold geboor en getap.
Ek beplan om die gauges in die consol bokant die radio in te sit.
gupster
Full Name: Barry Guppy
Nickname: Baz
Home Town: Hibberdene
2005 Nissan Patrol 3.0 GR
Has thanked: 136 times
Been thanked: 31 times
Re: Auber ETG Gauge
Post by gupster »
Hi Paul.
The chap who drilled and tapped my manifold was quite concerned that it was cast iron and it may start to crack. What is your and other forum members opinion of that?
Have Troll, will travel.
juice
Full Name: greg justus
Nickname: juice
Home Town: benoni
Current 4x4: patrol 2001
safari 1984 wagon
safari 1982 wagon
Home Language: english
Has thanked: 1 time
Been thanked: 12 times
Re: Auber ETG Gauge
Post by juice »
I drilled my manifold between 3 and 4 cylinder , four years ago and it is still going strong
juice
PaulvdMerwe
Nickname: Paul
Re: Auber ETG Gauge
So after seeing how small the Auber Instruments gauge is, i did not want to give up the console space above the radio, so decided to fit it on the right side below the instrument cluster..
Works great and alarm is set at
Re: Auber ETG Gauge
looks good !!
Has thanked: 1141 times
Been thanked: 1049 times
Re: Auber ETG Gauge
That looks excellent.
Can this gauge handle multiple functions too?
PaulvdMerwe
Nickname: Paul
Re: Auber ETG Gauge
Peter,
Auber uses the same gauge for various functions, but one gauge - one function. I will get another one that can do the Boost.
They do have a duel one that can do 2 functions.
Re: Auber ETG Gauge
Thanks Paul.
Re: Auber ETG Gauge
Paul, looks good!!
What did this unit set you back?
PaulvdMerwe
Nickname: Paul
Re: Auber ETG Gauge
Thanks Michael.
With postage from the USA just under R2000
I went for the more expensive prope though.
