Roll angle vs fuel starvation
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
Post by AndriesS »
Just out of interest sake , on our trip to Sodwana we pulled off on quiet a steep embankment, I would guess around 25-30 degree (left wheels below right wheels). We left the engine running , stretched legs, swapped drivers kicked the tyres etc and when I was all buckled up and ready to go when the engine died. We were just above 1/4 mark on the main tank . Maybe it was arrogance / gut feel but I switched on the sub tank transfer and within a minute I could start it. And luckily I did not have to prime it :biggrin: .
End of the day my view of it was that we had fuel starvation from the angle we parked . Does anybody know what the real angles vs starvation angles are, hit a 45 degree incline and running out of petrol cannot be fun .
Normally when we do our day outings I like to have a 3/4 tank plus sub ready .Most of the obstacles we do in these day trips are short lived and you power through the obstacle in seconds. Might be worthwhile knowledge for those overland/ long distance trips where you might need to top up from your jerry can before you tackle the next section to ensure you remain above the mark.
Re: Roll angle vs fuel starvation
Die petrol pomp is meer in die regter kant van die tenk!
So as jy stop met die bestuurder se kant laer dan gaan jy nie weer hierdie probleem kry nie.
Marino4x4
Full Name: Marinus Potgieter
Nickname: Marino4x4
Home Town: Bloemfontein
Current 4x4: Nissan Patrol
Has thanked: 17 times
Been thanked: 87 times
Post by Marino4x4 »
The drawing is very simplified, but the petrol pump sits in a bit of a bowl on the right hand side of the tank. This assist when you drive up hills. When you stopped, the little bowl was emptied and the engine stopped due to fuel starvation.
Petrol Tank.JPG (152.17 KiB) Viewed 3540 times
Patrol 4.5 GL 1998
Terrain 4X4 Parts
