TB48DE engine timing
Strandblom
Junior Member
Junior Member
Full Name: Jacques du Plooy
Nickname: Jacques
Home Town: Cape Town
Current 4x4: '03 Nissan Patrol 4.8 GRX
Post by Strandblom »
Good monring all, I just purchased the Nissan Data Scan software and is busy doing diagnostics. Does anyone know what the timing should be on the 4.8? I read somewhere it should be between 5 and 10 degrees BTDC. Is this correct? Any information would be appreciated..
Re: TB48DE engine timing
I will check in my manual when i am home tonight ....pm dawid he has played with his timing with a lot of success :salute:
Bruin Beer
Full Name: Riaan Delport
Nickname: Rooian
Been thanked: 21 times
Post by Bruin Beer »
Strandblom,
Dit is 5 Grade BTDS as jy die gewone fonkproppe gebruik maar as jy daai goed wat van goud gemaak is :lol: (spot net, die prys laat bit blyk dis van goud) die ek dink piladium plugs gebruik is dit 10 Grade BTDS volgens die manual.
Hoop jy kom reg.
Riaan
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
Post by David »
Moet nie die NDS gebruik om jou timing te stel nie - Gebruik 'n Timing Light.
Nissan Data Scan wys as ek reg onthou +-35 grade wanneer hy volgens die timing light 10 grade is
tour de frans
Been thanked: 22 times
Post by tour de frans »
5 grade btdc. Op idle werking tempratuur sonder aircon.
Aircan aan voeg die ecu nog timing by, so met meer as 5 grade timeing kan die kar knock met aircon aan.
Gu y61 wagon- 6.0L chevy
Gu y61 pickup- 6.2L chevy
David
Nickname: David
Post by David »
From the manual: :thumbup:
Strandblom
Junior Member
Junior Member
Nickname: Jacques
Baie dankie, ek het dit laas met die timing light gestel, maar ek sukkel om 'n lekker konneksie te kry met die inductive timing light. Die pick up gaan natuurlik met moeite oor die draad van die no.1 coil, en dan lyk my sukkel dit so bietjie om die spark op te tel, is dit normaal omdat die 4.8 'n draad het wat op die coilpack inprop in plaas van 'n gewone plug lead soos meeste ander motors?
David
Nickname: David
Post by David »
Mine pick up the signal OK but you can make an extension with a normal plug wire if you struggle. :thumbup:
