4.8 Motor / Any interest
Coltenator
Full Name: Quentin Hagen
Nickname: Coltenator
Home Town: Saldanha bay
Current 4x4: 2006 4.8GRX Patrol
2001 3.0 v6 Colt Rodeo D/C SOLD
Post by Coltenator »
Hi Guys
I am thinking about replacing my 4.8 motor with a diesel motor.
It has 124 000km on it and a full service history.
It will be without gearbox.
I can only do the swop to diesel if I know someone would be interested in buying my motor :think:
Quentin
2007 Patrol 4.8 GRX
Drwr system,Frdg,dbl bat systm ,Cheetah roofrack,35" m/t tyres, rear air helpers, snorkel
COLT RODEO 4x4 D/C 3.0 V6
Full ome susp,50mm bdylift,33" m/t,branches,fflow,chip,custom frt ,rear bumpers,rock sliders,dual bat systm
Abri Hoffman
Full Name: Abri Hoffman
Nickname: Abri
Home Town: Monument Park
Current 4x4: 2013 FJ Cruiser
Been thanked: 7 times
Re: 4.8 Motor / Any interest
Post by Abri Hoffman »
Price is always a factor. What is your expectation?
2013 FJ Cruiser
"Jack Russel"
Gaan die diffs se rating nie ook 'n probleem dan wees nie want ek weet nie of die 4.8 en diesels dieselfde diff het nie.
Verkoop jou 4.8 en koop n diesel .....die grx 4.8 het baie dinge wat met met mekaar praat ....engine praat met ratkas ens jy kan jou kar verkoop vir 200k en n 4.2 turbo diesel in n 4.5 grx body inbou vir 50k maak meer sense vir my :mytwocents:
Of kyk uit vir n 30l diesel wat nog jonk is 2007 +
Sodra jy die 4.8 uithaal is daai kar niks meer werd nie :oldtimer:
Coltenator
Update
So ek het met Mike gepraat by Rocket 88 en dit is wat besluit is.
Gaan n 383 stroker v8 petrol insit.
Behoort die makliker ombouing te wees en ek behoort al die krag te kry wat ek soek
en ook beter brandstof verbruik.
So die 4.8 moet gaan gehoop vir tussen 40 en 50 k.
2007 Patrol 4.8 GRX
Has thanked: 61 times
Been thanked: 257 times
Quentin
Is it just more power or better consumption, or both that you are looking for?
Another option would be to turbo charge the engine.
I still think you should be able to get a reasonable price for the car as it is now.
Then buy a Patrol with a sick engine, to replace.
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
Post by David »
But why? If there is nothing wrong with the 4.8 I think you are making a big mistake :think:
Diddo on what Dawid said....
Just follow the history on the forum and look for yourself....
What ever the price is double it to finish the build ....
Have a look at getting gearbox to work with engine...getting instruments to work on dash ect....
Imho if you want to have the big power put a super charger at rob green .
There is a LS3 patrol avalible for 170k with all the bells and whistles on .buy that one give it to frans to do the last bits and het it sorted if its not done.
Tommie went the correct way by using a manual 4.5 as a start
Have a chat to the guys that did this before ......
You can get more than 180000 for your car as is . Then you are where you want to be..... :mytwocents:
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Post by Wilkie »
Hi Guys,just my opinion
don't think conversions is simple,there is ALWAYS a clich...!!!!
I,ve been working on a 1980 Nissan Safari for the last 4 years,big ideas ,lexus v8 auto box etc etc
build the motor mounts and installed the v8,that was easy.....!!!
Then
sump hitting axle,lift suspension,ah propshaft to short,propshaft now hitting cross members,revcounter overreading and the list goes on and on.
End result,i have gone back to a recon L28 motor and standard gearbox and should have that vehicle running before end of this year Perfectly : http://www.patrol4x4.co.za/posting.php? ... =44&t=4943#
BETTER THE DEVIL YOU KNOW THAN YOU DONT KNOW
Have a blissfull weekend in your Pure Nissan
bogeyman
Full Name: Christo Boegman
Nickname: Chris
Current 4x4: 2005 4.8 GRX
Been thanked: 102 times
Post by bogeyman »
I agree.
If you want a vehicle that is unreliable and eats all your spare cash , do the modification. Then expect to exhaust your curse word stockpile.
It has been said before on this forum: If you have to modify , modify it back to the original.
Chris.
