Advice needed - oil leak and fanbelts
Johan B
Full Name: Johan Buys
Nickname: Johan
Current 4x4: Nissan Patrol 4.2D GL '99
Post by Johan B »
I got my 4.2d GL 99 over the weekend, I need to sort out two oil leaks on the front and rear diffs (only sweating oil), and replace the 3 fan belts and the plastic part of the fan itself as it has small tears in the fins.
Where and how is the best to go about this?
tour de frans
Been thanked: 22 times
Re: Advice needed - oil leak and fanbelts
Post by tour de frans »
Hallo Johan,From where are you?
Rdgs
Gu y61 wagon- 6.0L chevy
Gu y61 pickup- 6.2L chevy
Johan B
Nickname: Johan
Post by Johan B »
Gauteng
tour de frans
Hi Johan,Welcome to the forum.In Cape Town I can help you,but you are a little far.
Rdgs Frans
SRXy
Full Name: Wes
Nickname: the Knob...
Home Town: Slaapstad
Current 4x4: TD42T Patrol "The Wee Beasty", 373,000km's
Umm....this is a Patrol forum isn't it?
Home Language: engles
Post by SRXy »
Hi,
I actually need a new fan blade. Any suggestions where I can get one? I'm in Cape Town.
Dungbeetle
Full Name: Rudolf
Nickname: Dungbeetle
Home Town: Ellisras
Home Language: Afr
Been thanked: 69 times
Post by Dungbeetle »
After Nissan Stealers charged me R1600 deposit and supplied me a wrong one twice, I shoved it up their shelves and started looking for one second hand.
Some searching later I got a good second hand fan for my 2000 4.2D from from these ouks:
Nissan Spares
Mitch Pasqualli
Tel: 021 982 2680
Fax: 021 982 2681 or 086 672 1992
Cel: 083 273 8416
Pasqualli Spares & Repairs
c/o Lood & Wesselgeldenhuys Str Brackenfell Ind
P.S.
I suggest you remove the fan, photograph it and give them the exact dimensions.
Better replace that cracked fan - if it flies apart you will have major damage...
2012 NP300 DC - platkar
JG Shields
Full Name: JG Shields
Nickname: JG
Post by JG Shields »
I had to replace my 4.8's fan blade. After a world-wide search for a blade that does the right job, I imported a genuine Nissan blade from a Nissan dealer in Aus. Be careful for any aftermarket fan. The cooling fan is a very delicate and precise piece of equipment. The saving between the original thing and a aftermarket fan is not worth engine damage due to overheating.
Patrol fan!
SRXy
Full Name: Wes
Post by SRXy »
Dungbeetle wrote:After Nissan Stealers charged me R1600 deposit and supplied me a wrong one twice, I shoved it up their shelves and started looking for one second hand.
Nissan Spares
Mitch Pasqualli
Tel: 021 982 2680
Cel: 083 273 8416
P.S.
Thanks! I'll give them a try.
Is this the place?
I gave them a call and I'm looking at R750 for a second hand fan-blade....
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
Post by David »
SRXy wrote:Is this the place?
Yes - that is it. - Between Brackenfell and Kraaifontein just off the Old Paarl road.
They normally have 2nd hand engine spares for the older vehicles but not much for the newer Patrols. I got a few bits there for my old Safari.
