Posts: 5853 Joined: 13 Jan 2010 11:16
Has thanked: 591 times
Been thanked: 473 times
Post
by ricster » 19 Jun 2014 10:23
erasmusdries
Posts: 71 Joined: 29 May 2012 09:35
Full Name: Dries Erasmus
Nickname: Dries
Current 4x4: 2000 Patrol 4.2 GL
Been thanked: 11 times
Post
by erasmusdries » 19 Jun 2014 11:51
Have them at home will let you know tonight
Post
by ricster » 19 Jun 2014 13:27
Fantastic !!! Thanks
Posts: 7590 Joined: 29 Aug 2010 13:07
Current 4x4: Nissan patrol 4.8 GRX 2005 Toyota 2.7 legend 35 LWB 4X4
Has thanked: 802 times
Been thanked: 562 times
Post
by Tinus lotz » 19 Jun 2014 13:53
Cedric they are different between different models.... just check depending on what aircon ect.
Post
by ricster » 19 Jun 2014 14:24
As far as I know the TD42 motor hasn't changed its setup between the GQ and GU. The only difference was the alternator having a vacuum pump fitted on the rear of the alternator. The pulley setup and sizes should all be the same due to nothing changing on these motors. I assume there was changes on the Petrol motors.... but luckily I have the 'ol donkey motor
Post
by Tinus lotz » 19 Jun 2014 15:13
When mr boegman broke a belt on his bakkie there were 3 options and only one fitted if iam not mistaking
Just test the belts before you take with as a spare
erasmusdries
Nickname: Dries
Post
by erasmusdries » 19 Jun 2014 17:32
Cedric I have a 2000 model 4.2D and it uses the following belts:
1.Power Steering oil pump: 11950-VB20A
2.Fan and altenator: 11720-0Y700
3.Aircon: 02117-95023
Hope it helps
Post
by ricster » 20 Jun 2014 09:26
fantastic thanks for this info!!
Post
by ricster » 20 Jun 2014 10:03
What make are they?
Ross
Posts: 289 Joined: 19 May 2009 13:41
Full Name: Ross Holland
Nickname: Ross
Home Town: Cape Town
Current 4x4: 1998 GU 4.2 Turbo Diesel aka "The Polar Bear"
Has thanked: 7 times
Been thanked: 14 times
Post
by Ross » 24 Jun 2014 09:24
Hi Cedric,
I have a full spare set in the back of my van....just pulled them out.
Not sure off hand which belt is which, but they are all Ram Gatorback brand, part numbers for my 1998 model are as follows:
PG476
PG468
PG480
Hope that helps!!
Ross
Ross
