Should I drill a second hole in the rim
erasmusdries
Full Name: Dries Erasmus
Nickname: Dries
Current 4x4: 2000 Patrol 4.2 GL
Been thanked: 11 times
Post by erasmusdries »
Hi Guys
After losing a tyre I bought a TPMS system from Abraham on the community forum.It is the screw on type-JETTE for R1850- 6 tyre system.I want to use it on a steel patrol rim.It seems as a short valve stem would work but cannot find any in Pretoria east,do anyone know where I might find any as I believe you can get them or should I just drill another hole in the rim in a more protected area? :doh: :think:
erasmusdries
Nickname: Dries
Re: Should I drill a second hole in the rim
Some feedback if anyone else had the same problem.Motorbikes have the same size valve as motor cars.Bought short valve stems from them and had them fitted. TPMS is protruding significantly less.Was never keen on drilling an extra hole in the rim.
MALAS -- h/v VISAGIE en POTGIETER straat [bel hulle eers en hoor voor jy ry] ek het STAAL valves by hulle gekry.
Rubber valves sal skud -- staal valve is solied en behoort te dien ..]
Gat inni rim ? ek sou nie .. maar kan nie regtig rede gee nie .. KLINK verkeerd
erasmusdries
Nickname: Dries
Dankie Oom Mac.Ek het hulle eerste gebel en die ou het vir my gese hulle het net standaard grotes.Die motorfiets een is baie kort.Die hele gedoente meet slegs 32mm met die deel wat bo die rim uitsteek is ongeveer 25mm
