High compression pistons?
Clem
Full Name: Clem Daniel
Nickname: Clem
Has thanked: 39 times
Been thanked: 39 times
Post by Clem »
Guys, are there any high compression pistons available for the 4.8?
Re: High compression pistons?
Why???? Did you break your motor? ?? :think:
Clem
Nickname: Clem
Post by Clem »
No Tinus!!! Not yet! But if you have ever put 10.5 radio pistons in an engine you will know how it runs - like a bat out of hell!
Zantus
Full Name: Barto de Koning
Nickname: Zantus
Home Town: Port Elizabeth
Been thanked: 5 times
Post by Zantus »
Found these guys in my search for uprated internals for the TB45, they have a few options for the TB48 as well.
http://www.spoolimports.com/CatalogueRe ... ectType=27
Chris Skinner
Full Name: Chris Skinner
Nickname: Chris
Has thanked: 10 times
Been thanked: 53 times
Post by Chris Skinner »
Would this be a worthwhile mod - what power benefits could one expect? :think:
Clem
Nickname: Clem
Post by Clem »
Chris, a mate of mine had 10.5 pistons in a 145" (that's right) Land Rover with the old 3.5 engine. My oath but that thing ran.
Essentially, it seems more power for a given amount of fuel.
Has thanked: 60 times
Been thanked: 255 times
If impact on consumption is negligible, and power is more, why do manufacturers not do this as factory spec?
Clem
Nickname: Clem
Post by Clem »
Whole lot of reasons I expect. More engine pressure = more heat and more strain on various components I imagine.
Has thanked: 1124 times
Been thanked: 1038 times
The problem is pre-ignition.
to allow the use of high compression pistons, high-octane fuel needs to be used.
Clem, from what I know of the places you travel to, I would not recommend this mod.
