Noisy back door!!!
- Full Name: Frans Reichert
- Nickname: Frans Reichert
- Home Town: Kimberley
- Current 4x4: Ford Ranger 4l 4x4 auto
Nissan Kingcab 4x4
Nissan Patrol 4.8 - Home Language: Afrikaans
- Has thanked: 3 times
Noisy back door!!!
What advice (except for removing the doors) can you guys give me, how to get my back doors quiet? Especially the bigger one with the spare wheel on.
- Full Name: Andries
- Nickname: None
- Home Town: Pretoorsdorp
- Has thanked: 28 times
- Been thanked: 38 times
Re: Noisy back door!!!
Noisy when opening or closed.
Opening - the big door's stay's bearings are stuffed and no amount of oil grease will fix.
Closed - I normally wipe all the door seals with Dash type spray and then grease the strikers as well as the buffer at the bottom. keeps it quiet for a while.
Nissan Kingcab 4x4
Wile driving, such a rattle I hate it...... I have sprayed it with Teflon spray, was better but still noisy, isn't there a way of setting the latch for more solid shut.
- Marino4x4
- Nickname: Marino4x4
- Home Town: Bloemfontein
- Current 4x4: Nissan Patrol
- Has thanked: 17 times
- Been thanked: 87 times
Hi
There are a small rubber fitting in the latch that wears out. If you put a small piece of rubber/foam on it, it helps with the noise. This seems the wear out over time, so needs replacement now and then. It is at the top, not the one at the bottom.
- Has thanked: 1136 times
- Been thanked: 1047 times
Both top and bottom latches are adjustable, and since your car is still new, I would start there. I find they have to be set pretty tight, so that the door needs a hefty almost-slam to get it closed.
Lubricate the rubber block/stop/guide.
- Nickname: None
Also check that the rubber stop is still in the metal bracket (center bottom of door opening). Mine has been dislocated when someone took something heavy out and slid it across the bracket just catching the rubber piece.
What size sparewheel do you have? bigger heavier with spacers will cause more stress on the door
- Full Name: greg justus
- Nickname: juice
- Home Town: benoni
- Current 4x4: patrol 2001
safari 1984 wagon
safari 1982 wagon - Home Language: english
- Has thanked: 1 time
- Been thanked: 12 times
I had the same problem , the top bracket on the door side has a little rubber that gets compressed or worn out I replaced it without adjusting
any brackets and noise is gone
juice
juice
- Chris Skinner
- Full Name: Chris Skinner
- Nickname: Chris
- Has thanked: 10 times
- Been thanked: 53 times
