Radiator
johannes.dieterich
Full Name: Johannes Dieterich
Nickname: Joggel
Current 4x4: Patrol 4.5l
Home Language: English/German
Radiator
Post by johannes.dieterich »
I am urgently looking for a newly imported or reasonably refurbished radiator for my Y 61, 4.5l petrol, year 2001.
The original one is apparently 14.000 Rand which I can't afford.
I need it as a matter of urgency. Any advise appreciated.
Johannes
Marino4x4
Full Name: Marinus Potgieter
Nickname: Marino4x4
Home Town: Bloemfontein
Current 4x4: Nissan Patrol
Has thanked: 17 times
Been thanked: 87 times
Re: Radiator
Post by Marino4x4 »
Hi Johannes
What happened to the original? Normally the plastic parts on the top and bottom breaks or starts to leak. This is due to the different thermal expansion of aluminum and the plastic. The plastic fatigues and crack. Mine was fixed by silverton radiators. Think it was R1500 or so. If it is a total wright off go to silverton any way and ask them for some assistants, mined you, you can use any radiator company. They might have a cheaper fix.
Patrol 4.5 GL 1998
Terrain 4X4 Parts
johannes.dieterich
Nickname: Joggel
Re: Radiator
Marino4x4 wrote:Hi Johannes
Thanks very much Marino,
I haven't seen what exactly broke off from my radiator. I took it to Graham Cummings who wanted to put in new pipes. When he pulled the old ones off parts of the plastic of the radiator must have broken off. He said the plastic was very brittle. I wasn't aware that this t could be repaired. Graham told me that I should get a new one from Nissan which he said costs 14.000 R (it turned out to be "just" 10.000R, but not available at short notice anyway). There seem to be a couple of other options though. I will most probably go to Silverton/Strydom Park tomorrow morning. Which Silverton branch did you use?
Johannes
Marino4x4
Nickname: Marino4x4
Re: Radiator
Post by Marino4x4 »
Hi Johannes
I am in Bloemfontein. Used the one here. They welded a aluminium tank to the top of my radiator. They added all the pipe fittings as well. Hope you find a cheaper solution.
Patrol 4.5 GL 1998
Terrain 4X4 Parts
Re: Radiator
Contact these Commercial Auto Parts guys 011 493 7010 or Commercial Operations <operations@caparts.co.za> they might have a radiator for you.
Marino4x4
Nickname: Marino4x4
Re: Radiator
Post by Marino4x4 »
Johannes
Another option is Euro4x4parts.
The big problem is to get it to SA.
Patrol 4.5 GL 1998
Terrain 4X4 Parts
Re: Radiator
BMW 7 series V8 has been used in Patrol with success -- you can pick 'm up for around R2000
johannes.dieterich
Nickname: Joggel
Re: Radiator
Kagiso II wrote:BMW 7 series V8 has been used in Patrol with success -- you can pick 'm up for around R2000
Thanks, Kagiso.
I will have one made out of alluminium; costs 3 grand plus VAT. If you need one at one stage and want to find out about my experience, give me a shout.
Johannes
johannes.dieterich
Nickname: Joggel
Re: Radiator
Marino4x4 wrote:Johannes
Hi Marinus,
Thanks so much for your advise.
Johannes
johannes.dieterich
Nickname: Joggel
Re: Radiator
Herrie wrote:Contact these Commercial Auto Parts guys 011 493 7010 or Commercial Operations <operations@caparts.co.za> they might have a radiator for you.
Thanks a lot Herrie,
I'll store the numbers of your spare guys for other sad occasions.
Take care,
Johannes
