Camplight brilliant and bright
- Vaatjie
- Nickname: Faffa
- Home Town: Welgemoed
- Been thanked: 1 time
CampLight has an ultra low power consumption and with the two modes of operation it makes CampLight a more attractive alternative to other 12V operating camplights. Power consumption on high will be 160mA and on dim 60mA (5% accuracy up or down). These lights can be mounted anywhere with terry clips or velcro.
CampLight is reverse voltage protected and it will not damage 12V batteries by draining them completely. It will switch to dim mode at 11V and turn off at 10,5V.
The 2 modes that can be selected is a normal mode and a daylight switch mode. The normal mode allows for CampLight to be switched between on, dim and off. In day-timer mode CampLight will automatically turn on when it gets dark and turn off after 6 hours or when it sense day light again.
Now you can set up camp, go for a safari drive and be welcomed back to a lit camp site. If you are already in your sleeping bag, just leave the light on and it will turn off by itself after 6 hours.
The light is easy to use, small and light weight. Extension leads and joining up of lights can be done with normal DIY wire and plugs. Pictures to follow.
Technical information:
Dimenstions (mm) 100 x 20
DC cable 2.5m
Timer 6 hour night timer
Protection Low volts and reverse polarity
Maximum volts 16V
Minimum volts 10.5V
Power Consumption On - 1.8Watt (150mA)
Dim - 0.7Watt (60mA)
Price range is as follows:
1 to 2 units R285 each
3 to 4 units R265,00 each
5 to 10 units R250,00 each
more than 10 units R225,00
The price exclude delivery and shipping costs. Contact me on 082 379 0801 or 021 913 7215
DC cable 2.5m
Maximum volts 16V
Minimum volts 10.5V
- IMG_0414.JPG (118.86 KiB) Viewed 3059 times
- IMG_0415.JPG (111.07 KiB) Viewed 3059 times
- Nickname: Kosie
- Home Language: TWEETALIG
Re: Camplight brilliant and bright
I like this type of gadgets, you can use it in your home, camping trailer,vehicle, actually anywhere.
This just proof when people buy stuff, dont buy anything that cant be used elsewhere,than it becomes a white elephant.
Any other clips thats available , like on you tube about this light?
Chaps I have just bought myself a LED LENSER Torch, well I can tell you it makes a LED Maglite se naam gat, groot gat.
Koos
Koos
Land Rover Discovery 3 TDV6
- Family_Dog
- Full Name: Eric Skeen
- Nickname: F_D
- Home Town: Klerksdorp
- Current 4x4: Hilux 2.7i IFS D/C
Hilux 2.2i SFA D/C
Prado 3.4 VX - Home Language: I try to be Fifty/Vyftig
- Been thanked: 19 times
Koos, fill us in please.
* Picture?
* Price?
* From where?
I use a "Multi-function LED Emergency light", powered by a 6v battery. Features a 24 LED lamp unit and also a 4 LED torch. Lamp run time is 100 hours in torch mode, and 50 hours in lamp mode. Fully portable, but will not fit in a cubby hole (unless your vehicle has a BIG cubby hole!)
-F_D
* Picture?
* Price?
* From where?
-F_D
Pra Dog: 1998 Prado VX 3.4
Hound Dog: 2000 2.7i SC 4x4
- Nickname: Kosie
Its the LED LENSER P17 takes 3 x d batteries.
http://www.thetorchsite.co.uk/LED_Lenser_P17_torch.html
I bought it from a guy in pTA , he buys it direct from the importers . Its approx R550.00.This is a torch!!!!!!!!!!, its got a 10 watt led.Its incredible.
I see Klahari.net also sells LED LENSER torches
Koos
Koos
- Vaatjie
- Nickname: Faffa
Hello guys. The lights were build purely for camping/overlanding purposes. That is why I made it as small as possible and with a day/night sensor and battery cut off protection. The other concern was power usage(see specs). When you go out on a game drive in the evening and you will only return ofter dark you use the day/night setting. When you arrive back at camp atleast one or two lights will be on.
This is not a bissiness for me, I made the lights to suit my needs and are selling some to cover my cost.
- JohnBoyZA
- Site Admin
- Full Name: John Murray
- Nickname: John Boy
- Home Town: Bloubergstrand
- Current 4x4: Patrol GRX 4.8
- Has thanked: 1046 times
- Been thanked: 231 times
Vaatjie ek sal graag een wil toetsbestuur. Waar werk jy, ook in Bellville?
Oops, sorry for the Afr.
- Vaatjie
- Nickname: Faffa
Yes John. I'll lendt you one to test drive. If you like it you can transfer the money and if you don't like it you just sent it back. So easy.
- Saltman
- Full Name: Herbie Hellstrom
- Nickname: Saltman
Manne
EK kan van die liggie se vermoee getuig - daar is nou permanent een in my sleepwa en een in die Patrol.
Ek vind die "bright" stelling is amper te helder en verkies die lae verstelling wat dan ook minder krag verbruik.
Soos Vaatjie se - die sleepwa ene is op die day/night setting en ek los hom "aan" as ek weet ek gaan bv na donker terug wees by die wa - in die bos werk dit lekker want dan is daar omgewingslig wanneer jy terugkom by jou kamp. En as gevolg van die lae kragverbruik, kan jy maar 'n lang kabel aanle, hy werk nog steeds lekker.
Vir visvang langs die kus werk die dingetjie baie lekker saam met 'n klein 12V sealed battery.
Sterk aan te beveel as jy lang tye van jou eie battery(e) afhanklik is.
Saltman:
- Pieter du Toit
- Nickname: PJ of ook Whitey
- Been thanked: 6 times
Hello Vaatjie,
I would like to get some of these lights - at least 2 to start with. Do you use a normal cigarette lighter plug or is it the hella plug?? Do you have "stock" available - if possible I would like to get them before this coming long weekend and could fetch them from you - I stay in Welgemoed.
Pieter du Toit
MUFASA
Cell no: 072 606 7007
Fax no: 086 500 9333
MUFASA
- Vaatjie
- Nickname: Faffa
Hello Pieter. Jammer man. Ek was bietjie van lyn af. Ek kry my PC borde in die week en dan behoort ek weer 100 liggies te he in die die volgende week. Ek bly ook in Welgemoed en kan ons reel om bymekaar te kom. Stuur vir my 'n Pm met jou kontak nommers en ek bel jou as ek 'n paar reg het.
Hulle kom standaard met 2.5m lead met croc klampe op die punt. Jy kan enige plug op sit. Kom kyk by my en dan gee ek jou 'n paar idees.
