Correct 15" Rim Width?
Aleric Meyer
Full Name: Aleric Meyer
Nickname: Aleric Meyer
Home Town: Brackenfell
Current 4x4: 2000 Nissan Patrol 4500 GRX
Has thanked: 1 time
Post by Aleric Meyer »
I've ordered 5x Kumho KL71 M/T 33"x12.5" tyres with 15"x8" white steel rims, which i will have panted black. The tyre guy assures me that the 8" rim width is correct and safe for the tyres. Do any of you have experience with this or an opinion? I drive a 2000 4.5.
Re: Correct 15" Rim Width?
I think it is fine!
are your mags going up for sale? sounds cool to me to!!! you need a rim that makes your tire fit squire so that your sidewalls dont bulge and get stabed by rocks and sticks !!! any thing from a 8" to 10" speak to PC he has the same size with same rims :thumbup:
Aleric Meyer
Has thanked: 1 time
I will keep the mags for when i sell the car.
ChristoSlang
Nickname: ChristoSlang
Home Town: Pretoria, ZA
Has thanked: 29 times
Been thanked: 137 times
Post by ChristoSlang »
I have the same size tires on 10J 15" rims and it works fine...
Christo (the snake man)
Has thanked: 1141 times
Been thanked: 1049 times
I have 33" x 12.5" x 15" BF A/T's on 15x8 Mags. I briefly had them on the standard 7" steel rims.
I believe The recommended rim sizes for these tires are anything from 8" to 10". The narrower they are, the better your sidewalls are protected but I believe that for best performance in sand the widest rims would be best.
Rudolph
Nickname: Rudolph
Home Town: Port Alfred
Has thanked: 107 times
Been thanked: 36 times
Post by Rudolph »
Also check and make sure the inner bore diameter of the steel rim fits over the hubs, I had to cut mine. Not sure if the Y60 and Y61 requires the same inner bore size.
Cheers.
duckitt
Full Name: Charles
Nickname: Charles
Home Town: Cape Town
Current 4x4: 4.8 GQ Patrol 4x4 & 1996 (4.8) SGL GU was n 4.2 Petrol
Post by duckitt »
jy moet net seker maak dat die senter gat groot genoeg is om oor die hubs te pas . ek het n wiel so verloor maar die 15 werk goed my kar loop met n stel
Charles Duckitt
Duckitt Security Services
online7584692@telkomsa.net
0837085003
0219766432
Hallo Charlie -- hoe was Moooorisjuss? :biggrin:
Return to “14. Rims & Tyres”
