Hi all,
My aircon compressor has ceased. Any advice? I am on holiday and due to one belt driving everything, cant even drive home...
Aircon mechanic in port shepston wants to sent it to auto air on in edenvale to be reconned...
Too scared to go to Nissan...
3.0d aircon compressor
- Full Name: Bruce Williamson
- Nickname: Unkredible
- Home Town: Rivonia
- Current 4x4: '05 Patrol 3.0GL converted to TD42i
- Home Language: E
- Has thanked: 27 times
- Been thanked: 24 times
285x75x16 MT
DC-DC Charger
285x75x16 MT
DC-DC Charger
- Full Name: greg justus
- Nickname: juice
- Home Town: benoni
- Current 4x4: patrol 2001
safari 1984 wagon
safari 1982 wagon - Home Language: english
- Has thanked: 1 time
- Been thanked: 12 times
Re: 3.0d aircon compressor
Hi
I have a spare one that i can lend you so you can get home
juice
zero 8 two five five seven 4 3 two two
juice
- Bruin Beer
- Full Name: Riaan Delport
- Nickname: Rooian
- Has thanked: 6 times
- Been thanked: 21 times
Unkredible,
Is it the pump that seased or the pully bearing?
With the belt off, is it possible to rotate the A/C pully freely?
If it does turn free the pully bearing is fine and it is the seased pump which breaks the belt as soon as the clutch ingage.
You can then unplug the A/C clutch connection on the pump preventing the clutch to ingage.
Fit new belt, get lots of water (for personal consumption back home) and you should be fine.
Suspect open windows back home will be the in thing in this situation.
Good luck.
Bruin Beer
Good luck.
Bruin Beer
- Home Language: E
Thanks,
I had the pulley bearing replaced at the coast - luckily bearing man had the part - the bearing came out in pieces, only had about 6 balls left. The aircon clutch was totally burned out, so I had it removed and managed to get home with the windows open :-)
Now I need to source a new / second hand aircon unit - any suggestions? I have spoken to Auto Aircon and they reckon they are unlikely to be able to recon it due to no spares availability...
285x75x16 MT
DC-DC Charger
285x75x16 MT
DC-DC Charger
