Diesel Filter Issue
Grant
Full Name: Francis
Nickname: Grant
Home Town: Rosendal
Hilux 2,4 4x4 SC Dakar
Been thanked: 26 times
Diesel Filter Issue
Post by Grant »
Gents who have the diesel trolls, Interesting post on the aussie forum,
http://www.patrol4x4.com/forum/nissan-p ... oad-62747/
Aries66
Full Name: Louis Naude
Nickname: Aries66
2011 Navara 3.0V6 V9X
Re: Diesel Filter Issue
Post by Aries66 »
Dankie Grant
Sal biekie die naweek kyk op myne.
Very interresting ......we have had simmalar problems on the generators normally a bitch to ffind !!!! :thumbup:
Full Name: SJC
Has thanked: 237 times
Been thanked: 203 times
Is this "fuel inlet filter" and a "banjo filter" the same thing? (I have read before about cleaning a banjo filter on the td42 - thread here somewhere)..
Been thanked: 1038 times
Fanus, banjo refers to the fitting seen in the referenced thread, which has a bolt with a hole down the centre and connecting cross-holes through which the fluid passes.
So I guess it probably is.
Wilkie
Full Name: Errol Wilken
Nickname: Wilkie
2004 BMW 3.0D X5
Post by Wilkie »
There are normally two of those banjo bolts one with an inner filter which is fitted onto the the lift pump being the supply from the fuel tank
The other one is fitted on the return side of the of the injector pump and has a ball and spring on the inside this is what keeps the pressure in the injector pump
very important banjo that one :mytwocents:
Has thanked: 189 times
Been thanked: 270 times
Nou wonder mens of iemand al ooit daarna gekyk het..... ek gaan nie krap waar dit nie jeuk nie, ma sal interresant wees om te sien of dit al ooit skoongemaak is!
Full Name: SJC
Hier is errens n thread op die forum waar Russ syne skoon gemaak het en voertuig het beter getrek daarna..
Maar ja seker soos die pcv valve, kyk die meeste mechanics nie na die goed nie.
Been thanked: 430 times
This is not applicable to every TD42, I have checked my pump before and it does not have this filter, also checked others.
I have checked a couple of ZD30's as well and could not find a pump which actually had this filter in.
I suspect that the diesel pump shops remove this when doing a recon and never replace it, not sure if it is actually needed.
Something you can check for me WWW
