New Cummins motors being developed for Patrol 2012
Russ Kellermann
Full Name: Russell Kellermann
Nickname: Russell Kellermann
2005 Patrol 4.2TD Wagon
Post by Russ Kellermann »
Check this out. Imagine my pickup with 210kw and 700nm or torque.
Here:
http://forum.patrol4x4wa.com/index.php?topic=3080.0
And Here:
http://www.patrol4x4.com/forum/nissan-p ... nes-72940/
Only thing is the sulphur issues. Ie: 15ppm. they would have to modify or choose different injectors, like they have had to do with the 4.5V8 D4D, although apparently they too have had to now postpone all launches due to fuel system failures in SA models....
Anyway check it out.
Has thanked: 1135 times
Been thanked: 1046 times
Re: New Cummins motors being developed for Patrol 2012
I admit to not reading all of it, but I got the impresion these engines are aimed at the Y62, not the "real" patrols?
riaanvdw
Full Name: Riaan van der Walt
Nickname: Riaan
Home Town: Naboomspruit
Current 4x4: Bmw 330d (not a 4x4)
Post by riaanvdw »
If/When these powerhouses reach us, they might be de-tuned to suit african diesel. I've heard the new Rangers are de-tuned for this reason and that in Europe, they are much stronger :oldtimer: . I have no literature to back me up, it's just what I've heard.
Russ Kellermann
@ Peter = The new Y62 Pickup in UAE looks/is exactly like mine, yet is labelled the Y62, except they have been able to order it in a TB45 and TB48. Now, what the links above suggest, is that it will become available in the cummins version too in Africa. I also wonder how this is connected to the Y61GU as i was under the impression we were not to get the Y62 wagon....
@ Riaan = Totally agree, just like the cruiser V8 D4d as discussed! haha. Injectors bla bla bla. Ps: That ranger motor is a great motor it seems, regardless.
jeanne.volschenk
Full Name: Izak Jeanne volschenk
Nickname: jv
Home Town: Mbabane
Current 4x4: 4.5 GRX Patrol
4,5 GL Patrol
3,0 GL Patrol with td42motor
4,2tdi Pick up
2L Xtrail 4x4
69 Jeep Wagoneer
88 Range Rover V8
FJ 80 land cruise,
T6 XC90 Volvo
Post by jeanne.volschenk »
Hi Guys
I like the Cummins idea, however would prefer the 5.9 or 6.7 straight 6, I believe it to be simpler and more robust and Patrol like. I am currently looking into a 5.9 24V for my patrol. Nissan & Dodge have been looking at an agreement to replace the Titan's with Ram underpinings including diesels. For towing the Dodges straight 6 are rated better than the Duramax & Powerstokes V8. But Cummins Patrols is something to look forward to :blonde: . I even came accross a Land cruiser with a 2.8 (4) Cummins I suspect its the same as the Foton motor.
If they can be used in tug boats, then the engines must be good for Patrols as well!!
