PATROL Towing Hook Bolts
My Troll is fitted with an ARB Bull Bar. I would seem that when the Bull Bar was fitted that the OEM Towing Hook was removed. I have no recovery points/towing points in front (bought the vehicle like this).
Louis Naude (Aries66) was so kind :thumbup: to donate to me a Patrol Recovery/Towing hook.
This hook is normally secured to the chassis with three high tensile steel bolts.
Peter Connan provided :thumbup: me with the specs, but I am having difficlty :think: in sourcing the bolts. None of the specialist bolt suppliers in Pretoria have these bolts. I have also tried various Nissan Spares outlets and a number of 4x4 stores, but to no avail. Various Midas and Autozone outlets could not help either.
Can somebody please provide me with some guideance as to how I can source these bolts locally. :helpsign: I have a 1998 4500e GRX (M).
Re: PATROL Towing Hook Bolts
I will make a couple of phone calls after 08h00 when the shops are open, will let you know.
These bolts are either non-standard, or I measured like my backside. Either is quite possible.
I am seeing a friend this evening who'se car still has the hook attached, I will ask him to come in his Patrol (although it may already be too late) and if possible I will measure on a bolt, which is much easier than trying to measure a hole.
Aries66
Full Name: Louis Naude
Nickname: Aries66
2011 Navara 3.0V6 V9X
Post by Aries66 »
Sal een van myne vannaand afhaal, moet elk geval nuwe HT gegradeerde boute kry.
Hulle het my laasjaar op die AAWDC Funday gepenaliseer oor ek nog NISSAN boute op gehad het.
Ek weet wel dit is 'n baie fyn skroef draad wat hulle op daai drie boute gebruik.
Al hoekom die Cruiser ouens jou gepenaliseer het, is omdat jy 'n Patrol ry!
Die boute wat Nissan op gesit het in die fabriek is die regtes!
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
Post by AndriesS »
I got some at Northern Bolt supplies in Midrand.
Grootseun
Full Name: Driko Henningse
Nickname: Grootseun
Post by Grootseun »
My hook and bolts are stil llying around in my garage as it doesnt fit with the bash plate uless i make a chaneg or two i can measure wehn imm back form KZN on monday
2001 9.4 Patrol DI GRX
Bigger Intercooler
Oil Catch Can
PC Bash Plates
More Mods to follow
Thanks Guys for all the advice, assistance and the rapid and positive response. :salute:
Louis Naude (Aries66) arrived at my place today with a set of brand new high tensile bolts he sourced from an outlet in Pretoria.
My towing hook is now fitted. :dreads:
Baie dankie Louis!!!! :thumbup:
Aries66
Nickname: Aries66
Post by Aries66 »
Dit is 'n plesier. Mos maar die Patrol manne se manier.
Louis
:salute:
