R5K what will you spend it on
Full Name: Julius
Nickname: Jules
Current 4x4: Pathfinder
GQ Patrol
Home Language: AFR
Has thanked: 94 times
Been thanked: 76 times
Post by Jules »
Evening all
If you have R 5000 which accessory would you spend it on
1) Snorkel
2) Rock sliders
3) Drawer system
4) GPS & HID lights conversion
5) Custom seatcovers
6) 2nd Battery system ( fixed/removeable )
7)
These are the possibles I am considering, they are not really in order of preferance.
Comments and reasons will be appreciated
David
Full Name: David Prinsloo
Nickname: David
Home Town: Stellenbosch
Been thanked: 49 times
Re: R5K what will you spend it on
Post by David »
OK I will bite...
The HID lights are tempting but my OE's are actually not that bad... :doh:
For me it will be between the snorkel and second battery... OK make it the snorkel as I will get the most benefit from it for most of the time :thumbup:
Really depends on your needs as my single battery catered for my power consumption without problem but then again it is nice to have some backup that one time you over do it...... :redface:
Has thanked: 1141 times
Been thanked: 1049 times
David remember that Jules, like me drives an old Y60, and the headlights on these things are terrible.
I reckon you would get the most use out of the GPS & Lights, but if you want a real GPS you probably need to spend nearly the whole R5k just on that?
I don't think you ride hard enough to need rocksliders, and you can build a pretty good drawer system for half that (as I am attempting to prove to myself).
The snorkel is also a good investment methinks, but I would do the dual battery before the snorkel?
XenoBlitz
Full Name: Wilhelm van Rooyen
Nickname: Wilhelm
Home Town: Secunda
Current 4x4: The 4.5 Turbo
SWAMBO - 2007 Jimny
Has thanked: 66 times
Been thanked: 93 times
Post by XenoBlitz »
All the proposals are good, but personally, for me the weakest portion of the PAtrol (that needs updating) is the rear bumper.
Sooo many patrols have damaged their rear bumpers and it is VERY expensive to repair.
I would add to that list (somewhere near the top) a rear bumper, and while you're at it, a second sparewheel carrier (or jerry can holder) and a fitting for the high lift jack. Lastly, while you are replacing the rear bumper a PROPER towbar.
The rest of the Patrol is a beast. This one little weak spot will be a priority to get to the same standard.
The 4.5 Turbo
Wilfred Moore
Full Name: Wilfred Moore
Nickname: Wilfred
Been thanked: 4 times
Post by Wilfred Moore »
Hi Jules,
For me it will be between the Packing system and the second battery.. These things makes your life much easier.
Wilfred
Wilhelm, once again, Jules drives a Y60. The rear bumper on that is much stronger and less susceptable to damage than that of the Y61.
Having said that though, there is no doubt that a swing arm could come in handy at times.
JG Shields
Full Name: JG Shields
Nickname: JG
Post by JG Shields »
Fuel.....
Patrol fan!
Full Name: Julius
Nickname: Jules
GQ Patrol
Home Language: AFR
Post by Jules »
JG jy moet maar weer n Patrol koop lyk my die Patrol is heelwat ligter op brandstof as jou LC :rolling:
DANKIE SOVER AAN ALMAL SE INSETTE.
Sal n snorkel die lewensduur op jou enjin verbeter?
Jules skoon koue lug maak altyd sin praat met snorkel king syne lyk nie sleg nie ek dink n pbe stelsel kos onder 2000 jy kan dalk n snorkel en battery stelsel insit vir 5 en so bietjie???
jules - ekke en ons en jou realiteite verskil so bikki
oompie reken so - vat die ding vanne kant af en meet twee-twee teen mekaar en haal AF wat verloor - tot jy 'n wenner het vir JOU behoeftes ..
Soos ek nou op hirri oomblik, as een my met 5000bokke slinger dan koop ek Tswana bybels [en maar ek het darem al die GPS, die snorkel le inni graats vir opsit enni bumpers het ek ook al op Boezman, o-ja, die rock sliders ook]
Noodsaaklik teenoor 'nice to have' - dan moet die GPS daar wees. Snorkel as jy net vermoed jy gaan deur diep waters moet gaan [met jou Patrol - nie inni lewe nie] - en 'n sterk agter bumper om vriende [soos JG] te herwin. ... nee wat, dan liewer die voor buffer. :mytwocents: :mytwocents: :oldtimer:
