Chassis Rust
- Full Name: Ernst Dinkelmann
- Nickname: Ernst
- Current 4x4: Nissan Patrol 4.2 GR SE (Y60) 1995
Chassis Rust
Hallo
I have realised that my chassis has quite a bit of rust. I understand the vehicle lived near the coast and was even used for boat launching and the like. Remember, I never saw it before I bought it.
I have heard people speaking about sandblasting, repairing any obvious damage to the integrity of the steel and then rubberising the entire chassis.
What do you guys think about this and where do I go to get this done? I spoke to Safari Centre and they don't know who to recommend even.
Ernst
Ernst
Re: Chassis Rust
Take it to ITALIAN PANELBEATRS [Mitchell street; Pta West] Speak to Josè Costa - tell him I sent you - let him have a look and advise accordingly..
OR - if you want to try your own hand at it - Google "Popular Mecahnics" [SA edition] they have a full article on removing / repairing rust]
Sterkte met daai bogger -
- David
- Full Name: David Prinsloo
- Nickname: David
- Home Town: Stellenbosch
- Been thanked: 49 times
Re: Chassis Rust
I will not recommed rubberising as the rust will just grow beneath it. Sandblast and then galvanize the chassis
- Nickname: Ernst
Re: Chassis Rust
I have been referred to Protec in Silverton. Apparently they clean the chassis then sand the chassis, repair any areas that have damage and then paint with a product called "Rust Bust" This product is supposed to stop the rust from continuing, form a water tight barrier and serve as a primer for other paint.
I take the Patrol in on Monday to see their workshop and get an idea of their expertise. If I am not happy, I will look into the guys in Mitchell Street.
If I could, I would like to avoid having to remove the chassis from the rest of the body. I can just see something going wrong in the process.
Dankie Julle.
Dankie Julle.
Re: Chassis Rust
has yu a kemmira? sals yu taked the peectjirsz? [Hah ... kom ons kyk of Goeghil daai ene kan virtall
And keep us posted on this one [you are not the ONLY one with the brown stuff intrusion...]
Serious Ernst - Neem fotos van "voor" en "na" vir ons ander ook - As daai ouens se proses reg werk sal ek Lobo ook soontoe neem [daai blerri Diesel Dawg wat inni see gan rondry het met di earme outoppi - sjym]
- Been thanked: 1036 times
Re: Chassis Rust
Hi Ernst
I have used a product called Russist (not on my Patrol) which is similar to what you described above. It worked very well (I did not even really sand or clean, just steel brush and then paint), but would obviously not provide the same level of protection as galvanizing.
Also, if you do not strip the car down, there will be areas you miss, so you will have to keep fighting the rust that develops from there. Furthermore, and more seriously, you can't get into the inside of the chassis, but galvanising will.
Good luck
Peter
Good luck
Peter
- David
- Nickname: David
Re: Chassis Rust
Galvanizing is the only thing that will reach those deep hidden places but your chassis will possibly weigh 50kg more afterwardsPeter Connan wrote:.... you can't get into the inside of the chassis, but galvanising will.
On my old Safari I still had to take out rust every year even after using all those rust converter primers and sanding it down to bare metal
- Nickname: Ernst
Re: Chassis Rust
I'll go and have a chat with Protec in Silverton. It is starting to sound like galvinising is the only long term option. I dindn't even think about the inside of the chassis not being reached by this procedure - it almost begs the question : "What's the use?"
Usually when I do something, I want to go for the long-term option first, even if it is more expensive. And that is especially true for something like the chassis. It doesn't help taking the quick route only to spend more over time havign to repair it and later havign to either calvinise anyway or in the worst case look for another chassis.
So, who are the specialists with calvinising? Can any of you please post a picture of a calvinsed chassis?
Re: Chassis Rust
Hello Ernest
I have never galvanized something the size of a chassis. The galvanisers I have used up to now (for the bash plates) are Supergalv in Alrode, number is 011 908 3418, however I do not know if their tanks are large enough.
Alternatively try Robor on 011 876 2904
Try and find out if they have experience with chassis, as I have heard that the heat may twist something like a chassis (not sure if this was just scaremongering)
However what you are considering is quite a large job and will obviously take several weeks, are you OK for daily transport? The cost is likely to be R8.00/kg, not sure what the chassis weighs?
Peter
Peter
Re: Chassis Rust
Hello Ernst
Perhaps it is worth speaking to Juan to get this chassis? http://patrol4x4.co.za/viewtopic.php?f= ... 9&start=10
The chassis is almost identical, just a few small additions were made on the later cars to accomodate the longer nose. As far as I can determine, engine and suspension mounts are identical, as well as the main body mounts. That way you could prep the chassis, and then just transfer everything?
Peter
Peter
