Front wheel bearings
Jan
Full Name: Jan Schoeman
Nickname: Jan
Current 4x4: Patrol Diesel 2002
Post by Jan »
Hi All,
I have a 2002 Patrol GU and need to replace the front wheelbearings. Nissan only supply the complete hub with bearings @ +- R12,000 for the 2. Bearing Man cannot find the correct bearings on their system - it is not listed. I am however shure that they will have the correct sizes - can anybody please help and tell me what size/ref. number bearings I need ?
Thanks,
Jan Schoeman.
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
Re: Front wheel bearings
Post by AndriesS »
Hi Jan,
I haven't heard of any of the forum guys replacing their bearings yet. It's unlikely that bearing man will have it on their system but if it's not your daily driver why not quickly strip the hub off, I won't remove the outer ring yet but once clean you should be able to see a number on it. Are you sure it's the bearing though? or are you doing preventative maintenance?
If no-one replies maybe try Oz forum, they might have a number.
I did have some write up on this [maar ek sukkel met "search" op hirri forum, te vroeg uit die skool uit:
NORBRAKE DISTRIBUTERS cc; 5 Top Road; Anderbolt; Boksburg, 011 894 2371
OR Commercial Auto spares [find Under "Commercial Radiators"]
Also see Yellow Pages if "ACME Parts" are still in Rosslyn, they have ALL seals and bearings and such [they suply all the factories in Rosslyn ... at least last that I knew of [but ... times they are a-changin']
hi there
i think Wilfret Moore has got a spare set in his garrage
we can measure them and let you know! :mytwocents:
