Valve Clearances
stefnie
Junior Member
Junior Member
Full Name: Christo Muller
Nickname: Christo
Home Town: Orania
Current 4x4: 1998 Nissan Patrol 4.5 GL
Valve Clearances
Post by stefnie »
Hi Guys, does anyone know if the 1998 Patrol 4.5 GL (Y61) series have hydraulic lifters?
If not,and the valve clearances can be adjusted,what is the settings and procedure?
Thank you.
Christo Muller
Re: Valve Clearances
Christo - oompie dink jy moet vi Omie HERRIE (op safari) nader en mooi vra vir 'n "Patrol WorkShop Manual"
Russ Kellermann
Full Name: Russell Kellermann
Nickname: Russell Kellermann
2005 Patrol 4.2TD Wagon
Post by Russ Kellermann »
Stefnie, ive got a workshop manual , will have a look and report back to you asap.
Russ Kellermann
I can't find literature on weather or not they are Hydraulic, I'm sure Gerrit would be able to answer. Anyway, this is verbatim from Mx Ellery.
These adjustments should only be made when the engine is warm.
1: Remove engine rocker cover
2: Set the No1 piston to TDC (top dead centre i imagine) on its compression stroke and adjust the clearances on the No1,2,3,6,7 and 10 valves.
3: Set the No6 piston to TDC on its compression stroke and adjust the clearances on the No4,5,8,9,11 and 12 valves.
Specified Clearances:
Intake valves - 1,3,5,7,9,11 = 0.35mm
Exhaust Valves - 2,4,6,8,10,12 - 0.35mm
If the valves are not as indicated, adjust to suite (using feeler gauge, screw driver and ring spanner)
Replace rocker cover and tighten bolts to 1-3nm
Mrowka
Full Name: Kevin Mason
Nickname: Kevin
Home Town: Kiev
Current 4x4: 1994 Nissan Patrol 4.2TD
Post by Mrowka »
If you have to adjust clearances from time time, chances are the lifters are not hydraulic.
Патроль - эта вечная машина!
Russ Kellermann
Interesting, that does make sense though. hmm
Mrowka
Nickname: Kevin
Home Town: Kiev
Post by Mrowka »
Someone who is, like, smart and stuff should explain why Mr. Nissan built the TD42 with solid lifters and not hydraulic?
Most designers use solid lifters to prevent lifter float in high-revving engines. The TD42 is many things, but rev-happy it ain't, even by the standards of diesel engines.
tour de frans
Been thanked: 22 times
Post by tour de frans »
True,the 4.2 are also a amazing engine.The ausies rev it 6000rpm :surprised:
For what its worth.And I know the manufacture's give a spec for a reason.But here goes.A small valve clearance give power at high rpm,and a big but not noisy clearance make more horse at the bottom rpm. :wink:
Rdgs
Frans
Gu y61 wagon- 6.0L chevy
Gu y61 pickup- 6.2L chevy
penhoekpatrol
Full Name: Sidney Moorcroft
Nickname: Penhoek Patrol
Home Town: Penhoek Farm, Sterkstroom, Eastern Cape
Current 4x4: 2007 Patrol, 4.2D Pickup
Post by penhoekpatrol »
Hi chaps. Can anybody tell me what the valve clearances & head torque is on the 4.2d pickup (non turbo). Just bought another one & it has a bit of a tappet rattle & want to double check the head torque. Thanks chaps!
Been thanked: 473 times
Have a read through this post..... Its a bit long, but there is LOADS of info from Frans ( Tour de frans ) and you should find everything you need
http://patrol4x4.co.za/viewtopic.php?f= ... aiden+died
And this one...
http://patrol4x4.co.za/viewtopic.php?f= ... =30#p49905
