Brakes Binding
- Full Name: Adrian
- Nickname: Adrian
- Current 4x4: '91 SWB Patrol 4.2d
- Been thanked: 1 time
Brakes Binding
On the way back from Hennops yesterday there appeared to be something retarding my vehicle and I could only manage around 60km/hr in third gear. There is nothing wrong with the motor power, feels more like the brakes where being applied. Any suggestions on what it may be?
- Been thanked: 1036 times
Re: Brakes Binding
Hello Adrian
Is the problem still there, or did it disappear after the car has had a chance to rest?
If it is still happening, drive it a bit and then feel if any of the hubs are getting hotter than the others. Also check the handbrake drum (I think this is possibly the prime suspect).
Peter
Peter
- Full Name: Adrian
- Nickname: Adrian
Re: Brakes Binding
Hi Peter,
Thanks for the reply.
The problem seems to occur when the brakes heat up after driving for a while, it feels like the hydraulic pressure in the system will not release when the brake fluid is hot. I don't think it is related to the hand brake drum on the transfer box.
Re: Brakes Binding
clean out the mud & gunk around the cylinders & release springs (2) check the seals / rubbers of the MASTER cylindre, and while you're at it, the slave cyl as well. [also clear the collected packed up compacted gung & goo & mud inside te rim around the brake disks & pads}
- Full Name: Adrian
- Nickname: Adrian
Re: Brakes Binding
I traced the brake problem to a faulty master cylinder today. Anybody know where I can purchase a rebuild kit in Johannesburg?
Re: Brakes Binding
Hello Adrian
I have not specifically bought a kit for the Patrol, but Norbrake has always been able to help me in the past.
Peter
Peter
