Hey guys ,
3 quick ones
1. Is this an agent only part or available Aftermarket, Troll has been going really crap lately and today I discovered this pipe has a massive tear in it on the underside,like 5mm wide.
2.What are the correct plugs was supplied with BPR6ES But installed are BPK5e ???
3. I am also in need of a Brake Master cylinder Kit, Agents can only supply complete new , hell no . even a second hand Brake master can help ,
Any assistance will be highly valued
Cheers G
Intake pipe
- Been thanked: 1036 times
Re: Intake pipe
Th pipe may be available from Partsouq (on the net)?
BPR are the correct plugs. The number is the heat range, and the ideal may vary slightly between cars depending on how they are used. Using the wrong heat range mostly only affects the lifespan of the plug itself and maybe the performance of the engine as the plugs get older. I used to use BPR5ES myself.
As foe brakes, there is a guy in Centurion who does a great job re-building them. I think the company is called Natal re-sleeving.
