Speedo Correction
Rooster
Junior Member
Junior Member
Full Name: Andre du Preez
Nickname: Andre
Home Town: Rustenburg
Current 4x4: Amarok 3.0 V6
Patrol 4.8 GRX
Patrol 4.8 GRX - Supercharger
Been thanked: 13 times
Speedo Correction
Post by Rooster »
This is a write up for guys who’s speedometers are out with bigger tyres, this solution will work for both scenarios, faster GPS than speedometer or faster speedometer than GPS.
This might be common knowledge to some of you but nobody seemed to know whom I spoke to and the only solution was the speedo correction gadget that you put on your speedo cluster(like what Thys can do) but with that gadget, my cruise control does not work correctly it is extremely jerky because it wants to be 100% correct on the speedo.
When I received the parts ordered from partsouq, it took me roughly 15-20 minutes for compete job.
see attached PDF for instructions
Speedo Correction.pdf
(651.33 KiB) Downloaded 198 times
jonathan
Full Name: Jonathan Venter
Nickname: jonathan
Home Town: Jacobsbaai
Current 4x4: 2005 4.8 GRX
Has thanked: 9 times
Been thanked: 43 times
Re: Speedo Correction
Post by jonathan »
That's brilliant thanks André. Can you give a rough estimate of what the total parts and the import costs were?
ra_01
Full Name: Rahul
Nickname: Rahul
Current 4x4: Patrol 4.8 2016
Has thanked: 23 times
Been thanked: 62 times
Post by ra_01 »
This is great news. Thanks Andre
Rahul
Current Straight 6 :wink:
Rooster
Junior Member
Junior Member
Nickname: Andre
Patrol 4.8 GRX
Post by Rooster »
jonathan wrote: 21 Nov 2024 07:02 That's brilliant thanks André. Can you give a rough estimate of what the total parts and the import costs were?
Cost from Partsouq was $164 so about R2970.00 and DHL import costs was R1210.00
Return to “16. DIY Projects”
