Loosing watter
Digger
Full Name: Graeme Bath
Nickname: G
Home Town: Delmas
Current 4x4: 1998 Patrol 4.5 GL
Has thanked: 11 times
Been thanked: 11 times
Loosing watter
Post by Digger »
He guys , been a while, trust that you are all keeping well.
Small issue . well maybe not so small, seems that i am loosing water somewhere.
1. Nothing is leaking that its dropping on the Ground.
2. All pipes seem to be in good order with no visible signs of water
3. Radiator seems fine with no visible leaks
4. No water leaks in the vehicle , heater ETC
5. When idling there Doesnt seem to be a pressure buildup in the pipes , get very hot no pressure
6. Thermostat seems to be working no issues
7. Fans are all operational
8. Starts fine, Runs Fine , no missing.
9. Expansion tank no leaks
Help I am concerned that I have an expensive problem
Cheers Graeme
Digger
Nickname: G
Home Town: Delmas
Re: Loosing watter
Post by Digger »
Oils is fine as well. mot milky at all
Has thanked: 1134 times
Been thanked: 1044 times
Re: Loosing watter
Small water leaks can be very hard to find. A leak needs to be pretty significant before you will see water on the ground.
The expensive problem would have one fairly clear symptom: white smoke, especially against compression (ie coasting to a stop in gear, foot off the throttle or doing the same down a hill).
Most likely it is one of the small pipes a welsh plug or one of the radiator/heater matrixes after all.
Look carefully for anti-freeze stains.
Digger
Nickname: G
Home Town: Delmas
Re: Loosing watter
Post by Digger »
Thank you Peter , i will pull her over the pit and peek from the bottom.
Cheers Graeme
Re: Loosing watter
I have a pressure test kit connect to radiator cap and pump up ...at least you can see where it sprays out
Digger
Nickname: G
Home Town: Delmas
Re: Loosing watter
Post by Digger »
Maybe not a bad option , could look for one of those , thanks
