1991 safari thoughts
- Been thanked: 1036 times
Re: 1991 safari thoughts
From a South African perspective (and with very little knowledge of the US situation):
This is probably the most sought after version of the Patrol here in South Africa. Note that this is a Y60, which would be called a Patrol here, not a Safari, but they mixed and matched the names in different sales regions.
But that is because shorties are extremely scarce.
Having just owned a long-wheelbase Y60, most of the running gear (gear box, transfer case, axles, suspension components) will be familiar to you as they would be basically the same as on your previous car (there may be detail differences such as whether or not the rear axle has an LSD or a locker, and the rear suspension may have a built-in sway bar disconnect. Springs and shocks will be different due to the weight.
The area of concern is that there appears to be rust on the body, and the condition of the engine. If these TD42's are neglected they often overheat and crack the head. Rebuilds are expensive but parts are at least still available (may have to be imported though, not sure if that engine was used for anything that was sold in the US in any quantity).
I think it deserves a close look, depending on how far it is to you, but that price seems very high from a South African perspective. You could get a very good condition one here for that money.
The Y60 series Nissan Patrol GQ was marketed in USA and some other countries in the Americas, was marketed as FORD MAVERICK [some time after the NISSAN TERRANO her and Europe was also badged Ford Maverick
SO - all the info on the Nissan GQ / Y60 / Safari is readily available under the Ford Maverick tag on Google
https://www.google.com/search?q=Ford+Ma ... nt=gws-wiz
- Full Name: SJC
- Has thanked: 237 times
- Been thanked: 203 times
https://patrol4x4.co.za/viewtopic.php?p=120000#p120000Kagiso II wrote: ↑07 Oct 2022 18:58 The Y60 series Nissan Patrol GQ was marketed in USA and some other countries in the Americas, was marketed as FORD MAVERICK [some time after the NISSAN TERRANO her and Europe was also badged Ford Maverick
- Full Name: Gwilym Griffith
- Nickname: Gwilym
- Home Town: Tucson
- Current 4x4: Fj80
- Been thanked: 11 times
It was "marketed" but was it ever sold. I can't seem to find any fords. Also, from my understanding patrol was not allowed in US for poor safety crash test results. Hence no fords as well, but I'll look.
BTW the swb safari is canadian dollars and i saw the rust and canada has harsh winters so engine
Here is another but the price is ridiculous
https://m.facebook.com/marketplace/item ... EE_DETAILS
- Spike
- Full Name: Spike Pretorius
- Nickname: Spike
- Home Town: Milnerton
- Has thanked: 77 times
- Been thanked: 87 times
It was sold as a Maverick in Australia not the US.
When I first saw this thread three things came to mind.
1. It's a lot of money for a "beater", relatively by American standards
But on the other side of the coin
2. It's an import diesel which are very sought after there, and
3. It's very low mileage for a diesel. Still plenty life left in it
So I suppose if you can get your head around the price then it's a good truck to go for
Sardonic Fattist
