TB48 coil packs
Tomc
Full Name: Thomas Cumming
Nickname: Tom
Home Town: George
Current 4x4: Y61 GRX 4.8
Been thanked: 12 times
TB48 coil packs
Post by Tomc »
Good morning, anyone have TB48 coil packs for sale?
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
Re: TB48 coil packs
Post by AndriesS »
I have some old ones from a head I bought, if no-one have for sale then contact me and we can make a plan, maybe borrow a couple ( don't know the condition of the full set) until you have confirmed that you have a dead pack and then replace with new? search on forum JTEC bought some from overseas I think at a reduced price , some reason I think that the vk45 uses the same coil pack.
Tomc
Nickname: Tom
Home Town: George
Re: TB48 coil packs
Post by Tomc »
Dankie Andries, sal laat weet. Groete
JTEC
Full Name: Jade Dafel
Nickname: JTEC
Home Town: Somerset West
Has thanked: 164 times
Been thanked: 64 times
Re: TB48 coil packs
Post by JTEC »
Here is the link to the ones I purchased. Seems that sale has ended but could be more. Hope this helps :thumbup:
https://www.ebay.com/itm/Set-of-8-NEW-I ... 3445011327
GQ Patrol TD42
ex GU Patrol TB48
Bokdrol Adventures
Spike
Full Name: Spike Pretorius
Nickname: Spike
Home Town: Milnerton
Home Language: Sleg soutpiel
Has thanked: 77 times
Been thanked: 87 times
Re: TB48 coil packs
Post by Spike »
I discovered a couple of incorrect coil packs on my car. They look similar and have similar spec but the shaft on the one type doesn't reach fully to the spark plug and doesn't seal properly at the tappet cover.
I modded them to fit by trimming the lug carefully but then discovered that they also touch the tappet cover so had to swap the location around to fit one at the recessed part of the tappet cover under the intake, and the second one needed another minor fabrication to move the lug a few degrees to make it fit at a different angle and miss the tappet cover
So, shorter version of the story, be careful what you buy
(edited to resize the photo again)
coils v2.jpg (187.64 KiB) Viewed 3661 times
:oldtimer:
Sardonic Fattist
JTEC
Nickname: JTEC
Re: TB48 coil packs
Post by JTEC »
Spike wrote: 10 Jan 2022 11:14 I discovered a couple of incorrect coil packs on my car. They look similar and have similar spec but the shaft on the one type doesn't reach fully to the spark plug and doesn't seal properly at the tappet cover. I modded them to fit by trimming the lug carefully but then discovered that they also touch the tappet cover so had to swap their location around until all six fitted with the bad guys having enough space.
Good point spike! Also had one odd coil in mine before I replaced them.
Thankfully the ones I bought were an exact replica and worked a charm. :thumbup:
GQ Patrol TD42
ex GU Patrol TB48
Bokdrol Adventures
