LSD diff
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
LSD diff
Post by AndriesS »
IS it possible to change the internals from a diff lock unit to a LSD unit on a GU H260?
These days an LSD will serve me much better than the normal diff lock.
NoPressure
Full Name: Ruan
Nickname: Ruan
Home Town: Swakopmund
Has thanked: 88 times
Been thanked: 58 times
Re: LSD diff
Post by NoPressure »
The carburetor TB45 wagon has an LSD in the back. So I am sure the internals will fit, but I don't know of its a simple plug and play install.
AndriesS
Full Name: Andries
Nickname: None
Re: LSD diff
Post by AndriesS »
thanks will investigate that
Re: LSD diff
Carby TB45's were neversold here.
I do believe that most TD42 wagons had LSD but I i'm not sure if they had H260's or H233's
davidvdm
Full Name: David vd Merwe
Nickname: David - Hillbilly
Home Town: West Coast
Been thanked: 48 times
Re: LSD diff
Post by davidvdm »
Do all H260's take the same center portion?
The H260 I have, I believe is the HD version, 4.88 gears, right drop with LSD. Came from a 1980-83 Safari bakkie.
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
AndriesS
Full Name: Andries
Nickname: None
Re: LSD diff
Post by AndriesS »
Hi David, please Pm your contact details
Re: LSD diff
Andries that is out a safari not the same as gu
davidvdm
Re: LSD diff
Post by davidvdm »
Yip, and is in use in my Sani Hardbody. Sorry if my post was misleading.
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
davidvdm
Re: LSD diff
Post by davidvdm »
Tinus lotz wrote:Andries that is out a safari not the same as gu
Tinus, where can I find out what bearings I need to overhawl this diff of mine. The guys on the west coast take six weeks to do a job, and I cant be without my rig for that long. So I want to buy in the spares to try speed up the process.
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
Re: LSD diff
We have it phone me 0832978013
Sent from my SM-N975F using Tapatalk
