Windscreen Y60 4.2SGL (1995)
Overdrive
Full Name: Rod Crompton
Nickname: Rod
Home Town: Jhb
Current 4x4: Patrol 4.2 SGL
Has thanked: 7 times
Been thanked: 7 times
Post by Overdrive »
Does anyone have a part number for this windscreen?
My VIN is "stolen and replaced" so useless for searching part numbers.
Its a pretty expensive item and Nissan wont take it back if its the wrong part.
Patrol 4.2 SGL
Been thanked: 473 times
Re: Windscreen Y60 4.2SGL (1995)
Hey there Mr Rod !!.. long time no see !!
Doesn't PG and/or National Glass not make a windscreen for the Y60 Patrol? I recon it would be a whole heap cheaper than Nissan, and will be the proper shatterproof ones. I hear that some of the cheap import Chinese ones are not that great, but if from a reputable crowd it should be ok
Full Name: Julius
Nickname: Jules
Current 4x4: Pathfinder
GQ Patrol
Home Language: AFR
Has thanked: 94 times
Been thanked: 76 times
Post by Jules »
I ordered mine through PG Glass will look if i have part numbers for you , importantant that they order the correct unit . It is not a stick on windscreen took me about an hour to explain that to the PG Glass guy in Dbn
Overdrive
Nickname: Rod
Home Town: Jhb
Post by Overdrive »
Ja I'm working through a dealer but they want the VIN number to identify the correct part number and my VIN number is a "stolen and found" police VIN number which is useless for parts. Trying to get my lorry looking its best for the 70th birthday bash :lol:
Patrol 4.2 SGL
Overdrive
Nickname: Rod
Home Town: Jhb
Post by Overdrive »
Jules wrote: 08 Jun 2021 17:06 I ordered mine through PG Glass will look if i have part numbers for you , importantant that they order the correct unit . It is not a stick on windscreen took me about an hour to explain that to the PG Glass guy in Dbn
It would be much appreciated
Patrol 4.2 SGL
Overdrive
Nickname: Rod
Home Town: Jhb
Post by Overdrive »
ricster wrote: 08 Jun 2021 16:29 Hey there Mr Rod !!.. long time no see !!
Hey ricster! Work pressure dropping, sort of..... Trying to get more dust on my lorry. :wink:
Patrol 4.2 SGL
Not sure if this helps, but it's the same part as for the Safari which preceded it.
Overdrive
Nickname: Rod
Home Town: Jhb
Post by Overdrive »
:thumbup:
Patrol 4.2 SGL
mvcoller
Full Name: Malcolm van Coller
Nickname: mvcoller
1998 4.5 Patrol SGL
Home Language: Afr & Eng
Has thanked: 41 times
Been thanked: 186 times
Post by mvcoller »
Commercial Auto Glass in Selby and at any of their other outlets, sells them for R1000 and fit it the same day.
They actually fitted one in my Safari in 2006 for R600, one in my Y60 in 2010 for R1k and about 4 years ago one to my Y61 Patrol 3.0Di for R1k
Laminated shatterproof glass
Overdrive
Nickname: Rod
Home Town: Jhb
Post by Overdrive »
mvcoller wrote: 09 Jun 2021 16:03 Commercial Auto Glass in Selby and at any of their other outlets, sells them for R1000 and fit it the same day.
Thanks for the suggestion. I'll try them too. You wouldn't happen to have the part number? No one seems to be sure about the part number and the Shatterproof part numbers don't talk to the Nissan part numbers.
Patrol 4.2 SGL
