No sound over speakers
Francois Theron
Full Name: Francois Theron
Nickname: Francois
Home Town: Robertson
Current 4x4: 2006 Patrol 4.8 GL
Has thanked: 12 times
Been thanked: 29 times
Post by Francois Theron »
I have a very strange fault on my 4.8 Y61. The radio works 100% when speakers are connected to the plug at the back of the radio but no sound over the speakers when connected to the speakers in the vehicle. So there must be a problem further down the loom. All 4 speakers dead, not even a scratch or crackle!
Any idea from anyone pleae?
Is there perhaps a controller of some sorts or some other connection block or connector somewhere down the line on the way to the speakers?
Spike
Full Name: Spike Pretorius
Nickname: Spike
Home Town: Milnerton
Home Language: Sleg soutpiel
Has thanked: 77 times
Been thanked: 87 times
Re: No sound over speakers
Post by Spike »
Maybe they are muted by the button on the steering wheel
:oldtimer:
Sardonic Fattist
graham1
Full Name: graham robertson
Nickname: graham1
Home Town: Harties
Has thanked: 9 times
Been thanked: 100 times
Post by graham1 »
If I understand correctly, you mean, if you pull the radio out and connect a speaker directly to the back of the radio, the speaker works, but, the speakers in the doors dont work?
I have a slightly similar problem, my speakers work very intermittently, actually, only the tweeters in the dash, and the one rear left, the others are always dead. Must be a break/damage in the cables somewhere between the radio and the speakers.
ive just never built up the energy to re-run cables. I do need to get it sorted though!
Francois Theron
Nickname: Francois
No steering controls. Exactly as you describe Graham except that everything is dead
Francois, is there any possibility somebody in the past connected the speakers to an amp, and then removed it?
But I suspect yoh may have to trace the wiring...
johanp
Full Name: Johan Pheiffer
Nickname: Johan
Has thanked: 1 time
Been thanked: 26 times
Post by johanp »
Before you trace the wiring, remove one of the door panels and test with another speaker.
Both speakers on the driver side of my car stopped working and it was the speakers, not the wiring.
Any luck sorting this?
Francois Theron
Nickname: Francois
I am still busy sorting but it would appear as if it is indeed the speakers giving up
:bravo:
Well thats the best excuse for an upgrade ever!
Been thanked: 473 times
I can recommend Kicker Split System speakers, and if your radio can take a sub, a Kicker Slimline Sub works great... :blonde: :deathmetal: :rock:
Return to “13b. Audio Systems”
