Aircon Hot and Cold
Maniac
Full Name: Manie Carstens
Nickname: Maniac
Home Town: Durbanville
Current 4x4: Hilux DC
F62 LC
4.5 GRX Patrol
Home Language: Afrikaans / English
Aircon Hot and Cold
Post by Maniac »
Today being fairly to F%$#%$# hot, my aircon started acting up.
The ambient here at the moment is in the high 30's, and as Lady Luck would have it the aircon is doing funny things. It will work as normal, and then all of the sudden start blowing piping hot air through all the vents. The air is definiately hotter than outside air, so that indicates that it is being heated by engine water?
The faulty heater flap theory can not apply as it does cool for a bit an then heat again.
The "freezing" could be the problem, but then why is air piping hot when the pump goes off. I must add that when it is working it works very well, so I do not think it could be a combination of both scenarios.
Any advice would be appreciated
Manie
AndriesS
Full Name: Andries
Nickname: None
Home Town: Pretoorsdorp
Has thanked: 28 times
Been thanked: 38 times
Re: Aircon Hot and Cold
Post by AndriesS »
