Please help matic j Nissan navara automatic gearbox oil needed
Jasonr
Full Name: Jason
Nickname: Jason
Home Town: Durban
Current 4x4: Nissan navara
Post by Jasonr »
Hi guys
I need some help please. I'm currently searching for matic j fluid for my navara.
Pieter B
Full Name: Pieter Botha
Nickname: Pieter
Been thanked: 97 times
Re: Please help matic j Nissan navara automatic gearbox oil needed
Post by Pieter B »
Doesn't it take the matic S fluid?
Nissan centurion sells it by the liter
Jasonr
Full Name: Jason
Nickname: Jason
Home Town: Durban
Post by Jasonr »
Thanks for the response guys, the latest spec navara takes matic s but I can also use matic s. I will try nissan centurion, most of the dealers only stock 20 litres. I currently need 12 litres.
Correct way is to buy 20l and fill while you have the pipe off the radiator . When its clean red you know everything is changed . Normally you cant get the oil out the torgue convertor . So doing it that way you change it all
Jasonr
Full Name: Jason
Nickname: Jason
Home Town: Durban
Post by Jasonr »
Thanks Tinus for the advice, I will follow that procedure. I also want to remove the pan, do you recommend to change the metal sieve filter or just clean it. Dealers want R6000 for 20 litres
Reenen
Full Name: Reenen Kritzinger
Nickname: Reenen
Home Town: Greyton
Current 4x4: SFA Hardbody
4.8 GRX
V9X Navara
Safari Stasiewa
Safari Pickup
Safari stasiewa
88 Isuzu RD28 Nissan
1978 300D Merc RD28 Nissan
Been thanked: 125 times
Post by Reenen »
Gebruik die navara v9x 7 spoed dieselfde olie as die 4.8 grx?
Ek wil beide van my vervang.
Anthony Forgey
Full Name: Anthony Forgey
Nickname: Anthony
Home Town: Randburg
Been thanked: 202 times
Post by Anthony Forgey »
Jasonr wrote: 18 Jan 2021 12:03 Thanks Tinus for the advice, I will follow that procedure. I also want to remove the pan, do you recommend to change the metal sieve filter or just clean it. Dealers want R6000 for 20 litres
Just clean the filter. Use brake cleaner.
Reenen wrote: 18 Jan 2021 15:06 Gebruik die navara v9x 7 spoed dieselfde olie as die 4.8 grx?
Ek is onseker lees voor op jou slam try .
Jy kan net jou manual check
