27 Mhz whip antenae
Digger
Full Name: Graeme Bath
Nickname: G
Home Town: Delmas
Current 4x4: 1998 Patrol 4.5 GL
Has thanked: 11 times
Been thanked: 11 times
27 Mhz whip antenae
Post by Digger »
Hi Guys
Looking for a 27Mhz whip antennae on the east rand, just need the Whip portion or the entire unit,
Any assistance will be appreciated
In addition, what licencing is required, thanks a lot
G
Oetie
Full Name: Leon Fouche
Nickname: Oetie
Has thanked: 394 times
Been thanked: 141 times
Re: 27 Mhz whip antenae
Post by Oetie »
You can try Sams Radio in Gallo Manor, Sandton.
But why 27Mhz? I do not know if the CB band is still very active. Most people is on the ORRA VHF channels for which you can get the license through 4x4 Community.
Sent from my iPhone using Tapatalk
ORRA - L65
HAM - ZS6LEF
Tlou - 2009 Patrol TD42T
Digger
Nickname: G
Home Town: Delmas
Post by Digger »
Ok thank you,
Now I need some help then,
Trol came with this fitted, I assume then that this is no good
WhatsApp Image 2020-12-22 at 19.33.26.jpeg (110.49 KiB) Viewed 8746 times
Cheers G
Oetie
Nickname: Oetie
Post by Oetie »
I will not say it is off no use, there may be action there but limited. I will keep it and add a VHF to the Trol.
ORRA - L65
HAM - ZS6LEF
Digger
Nickname: G
Home Town: Delmas
Post by Digger »
Awesome thanks a lot, appreciated, so now I need to join a club I suppose and then for a radio.
Which club do you chaps recommend?
Cheers G
Spike
Full Name: Spike Pretorius
Nickname: Spike
Home Town: Milnerton
Home Language: Sleg soutpiel
Has thanked: 77 times
Been thanked: 87 times
Post by Spike »
A lot of (Cape) guys use 29mhz. I have them in my vehicles. They have their uses and are a good back up or second line of comms depending on what you're doing. While people are hannahannering on the VHF you can do private line on 29mhz to your maaaitjies. I've also been in situations where VHF comms was poor and the 29meg worked. Another lekker feature is you have a LOT of channels to talk on so never have congestion. Anyhoo, not to start the old VHF vs 29mhz debate, I'm telling you they definitely have a use, don't throw it away.
I use the same radio that you have in your picture. Some had both 27 and 29 frequencies programmed. Some only 27mhz. The 27 mhz ones I took to the local agent (in Cape Town) who flashed the firmware and loaded the 29mhz frequencies for R100
27mhz = old CB radios
29mhz = old maritime and 4x4 radios (and disaster management and bushfires blah blah)
:oldtimer:
Sardonic Fattist
Oetie
Nickname: Oetie
Post by Oetie »
No need to join a club if you buy the ORRA license through 4x4 Community
ORRA - L65
HAM - ZS6LEF
Digger
Nickname: G
Home Town: Delmas
Post by Digger »
Thanks will PM you later.
Pieter B
Full Name: Pieter Botha
Nickname: Pieter
Been thanked: 97 times
Post by Pieter B »
RF technologies in Alberton can sort you with an antenna. I've got a tel number of a guy that sorted and installed my VHF. PM me if you need his number
