Today I bash out a wheel stud to have a sample to get two new ones, and find the drum full of oil. Looks like its leaking from the tube seal. So how does this come apart, and has anybody got a part number for that seal.
And in a town like Parys, nobody will, or can get the same wheel studs thread pitch I need. Ask if they can get, they just not interested. Now ended up buying two packets Toyota studs of five in a packet to start replacing them all. They only have two packets, so I can't even do both the rear wheels. Will at least do one for now, and go search for more later in Cape Town when I get back there.
Anyhow, this leak is my biggest concern, can someone help with some info please.
H260 HD diff driveshaft oil leak
- davidvdm
- Full Name: David vd Merwe
- Nickname: David - Hillbilly
- Home Town: West Coast
- Has thanked: 4 times
- Been thanked: 48 times
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
- nisjeep
- Full Name: Peter Church
- Nickname: Nisjeep
- Home Town: Vredenburg
- Current 4x4: 1995 Patrol GQ SGL
2001 Terrano 2 - Home Language: Afrikaans
- Has thanked: 5 times
- Been thanked: 14 times
Re: H260 HD diff driveshaft oil leak
H260 full floater and h233b
888888.pdf
- (204.25 KiB) Downloaded 192 times
777.pdf
- (166.45 KiB) Downloaded 171 times
- davidvdm
Mine is the H260, with the third member, but don't see it being the full floater.
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
- Full Name: Andries
- Nickname: None
- Home Town: Pretoorsdorp
- Has thanked: 28 times
- Been thanked: 38 times
Parys must be a always going right town if they don't have M12 x1.25 studs . Nissan use it extensivelydavidvdm wrote: ↑05 Nov 2020 16:42
- Nickname: None
On my 4.8 gl with what I believe has a H260 diff. the seal details:
Nissan no : 43252-vh300. (I have one if you need it urgently and willing to replace)
Type:
Double lip
65 mm od
43 mm id. ( measured through a packet)
11 mm thick
On seal no : NCK bb5796f
A
Type:
Double lip
65 mm od
11 mm thick
A
- davidvdm
I'm out of time to get spares now. I did go see if Autozone has any idea of what I need, but I may as well have gone looking for a windmill for a chinese wigwam.
Still trying to raise the materials for a new crossmember across the front suspension. Still fighting a death wobble which wheel balancing, rotation and wheel alignment did not sort out.
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
- davidvdm
Yesterday coming back from town, I pick up a rattling noise from the rear when cruising at exact engine revs, no torque on diff, or running against motor, just cruising to maintain speed. This morning I pop in under the Sani to find that the pinion has a bit of play on it.
NOW WHAT???
I don't know shops here on the West Coast, and as usual, there is no budget to do this job
NOW WHAT???
David - Bfreesani
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
MQ C200 SFA
MQ H260 LSD Rear
5" Lift
DIY rock sliders
DIY Snorkel
Madman EMS
