222K Overlanding Parts Kit
- jan.dup
- Full Name: Jannie Du Plessis
- Nickname: Jannie
- Home Town: Hermanus
- Current 4x4: Patrol 4.8 GRX
- Has thanked: 30 times
- Been thanked: 13 times
My Patrol 4.8GRX is on 222000 Km. I was considering a swop for a newer/lower Km model but after some deliberation decided not to and rather jack up my existing Patrol. I mostly do solo trips (Zambia/Namibia/Botswana) and want to make sure (as far as possible) that I don't get stuck with a broken/dysfunctional vehicle with no one around. Therefor need some help/advice on what parts to replace or take a spare with, as well as where to source them if not from Nissan.
Replacements so far:
Radiator (about 10K ago)
Manual Hubs
Wheel bearings
Possible parts to replace/take spare with:
V-Belt set
Hose set
Viscous fan
Alternator
Petrol pump
I am also taking the Patrol to Frans for a thorough checkup and service. Any help/advice/recommendations would be appreciated.
Manual Hubs
Wheel bearings
V-Belt set
Hose set
Viscous fan
Alternator
Petrol pump
- Has thanked: 62 times
- Been thanked: 257 times
- TijmenvdS
- Nickname: Tijmen
- Has thanked: 32 times
- Been thanked: 112 times
Re: 222K Overlanding Parts Kit
I Highly recommend replacing the suspension bushes at 200+ Km it is very likely the dreaded death wobbles might start. Also with the auto a good flush and clean of the gearbox is not a bad idea.
- TijmenvdS
- Nickname: Tijmen
Others might also correct me if they don't think it necessary but a vehicle older than 15 years the difflock's rubber vacuum hoses tend to harden and crack which can slowly engage the difflock while driving, the diff will still work but realising the diflock doesn't work while on a solo trip is not lekker so replacing the rubber pipes and adding some hoseclamps could prevent a lot of issues.
- Full Name: Anthony Forgey
- Nickname: Anthony
- Home Town: Randburg
- Has thanked: 181 times
- Been thanked: 206 times
Here's some ideas I'd consider:
Starter motor
Alternator
Belts
Replace all the water hoses
check/replace radius arm bushes
check Drag link and tie rod bushes
Replace panhard rod bushes (Front and rear)
Probably handbrake cable if its not smooth any more
Vacuum hoses to locker and breathers (like Tijmen mentioned)
Flush water from the block
New thermostat
new Viscous clutch
Replace fuel pump
Starter motor
Alternator
Belts
New thermostat
new Viscous clutch
Replace fuel pump
- Nickname: mvcoller
- Has thanked: 41 times
- Been thanked: 187 times
I when you replace your radiator hoses and fan belts, keep the old ones and fasten them with cable ties somewhere in the engine bay as emergency spares.
At least you know that they will fit, they are instantly available and that they should still be OK if used in an emergency. Even new hoses or belts are known to have failed fairly soon after (incorrect?) fitment.
I did that in my Terrano and the extra (old/used) aircon belt saved me from getting hot under the collar in Kaokoland
- Has thanked: 1142 times
- Been thanked: 1049 times
If it's not done every couple of years, definitely replace the brake fluid.
- jan.dup
- Nickname: Jannie
Parts costs from Nissan will be in the vacinity of R 60 000
Any donations welcome
Nissan Helderberg in Strand - no stock - 21days waiting period:
V-Belt R 330.00
Powersteering Belt R 433.00
Aircon Belt R 330.oo
Lower Radiator Hose R 1884.02
Upper Radiator Hose R 704.81
Viscous Fan Coupling R 5827.00
Altenator R 14193.58
Petrol Pump R 3550.00
Starter R 12050.00
Thermostat R 704.12
Waterpump R 4884.00
They mentioned that there are 7 difflock hoses ranging from R 880.00 to R 1892.00
V-Belt R 330.00
Starter R 12050.00
Thermostat R 704.12
Waterpump R 4884.00
