Starter service
- Newbie
- Full Name: Wentzel Coetzer
- Nickname: Wentzel
- Home Town: Langebaan, Western Cape
- Current 4x4: '96 Nissan Patrol GQ 4.2
- Home Language: Afrikaans / English
Starter service
My '96 SGL Petrol starter has been giving some trouble with starting. I then approached Nissan only to be informed that the starter is a complete unit of which there is no stock. I have subsequently seen some posts on servicing of starters which leads me to believe that there is some or other kit available. Does anyone know ?
- Been thanked: 1036 times
Re: Starter service
I don't think there is a kit as such but most of the wearing parts shiuld be available loose from spares shops. The problem is that they probably won't know which parts to give you unless you have a sample.
The easy answer is that there are small busenisses that specialize in refurbishing starters and alternators, just give it to one of them. Any good auto-electrician should be able to do it or know of somebody who can.
- Spike
- Full Name: Spike Pretorius
- Nickname: Spike
- Home Town: Milnerton
- Has thanked: 77 times
- Been thanked: 87 times
Re: Starter service
I recently went down this road. The parts were difficult to find and were too expensive and it turned out cheaper to just buy a new one. Around 2k from Diesel Electric. I still have my old starter and may rebuild it one day if I find economical parts but I'm not too optimistic. Probably cheap and easily obtainable for an auto-electrician but I'm not in the trade
Sardonic Fattist
Re: Starter service
Does anyone know what grease is recommended for the starter??
- Full Name: Wietsche Swanepoel
- Nickname: Wiets
- Home Town: Delmas
- Current 4x4: Nissan Hardbody
Nissan Patrol - Home Language: Afrikaans
- Been thanked: 12 times
Re: Starter service
Middag ek het my eie starter gediens jy kry die borsels by midas was R40.00 n stel. En op my starter het hy 2 needle roller bearings in die voorste housing en agter ook was alles met thinners en maak die armature net skoon met bietjie emerytape op die draaibank en dit is n reduction starter gebruik die selfde ghries wat ek op my Ktm se nek se bearings gebruik. En hy spin soos n bom my bendix het niks markeer nie was nie nodig om te vervang nie en die 4.5 se starter is n mitsubushi eenheid maar is serviceabke en dit is baie maklik.
