3.0CRD Air Filter
Dungbeetle
Full Name: Rudolf
Nickname: Dungbeetle
Home Town: Ellisras
Home Language: Afr
Been thanked: 70 times
3.0CRD Air Filter
Post by Dungbeetle »
The Nissan OEM filter has a foam seal on one side and a rubber lip seal on the other. Now to install - which side up??? And why....
2012 NP300 DC - platkar
mvcoller
Full Name: Malcolm van Coller
Nickname: mvcoller
1998 4.5 Patrol SGL
Home Language: Afr & Eng
Has thanked: 41 times
Been thanked: 187 times
Re: 3.0CRD Air Filter
Post by mvcoller »
The folds go down.
Nissan does the filter in two varieties, one a dry paper filter, the other one is lightly oiled. If you drive on dirt, get the oiled one. That was the advice I got from the guy in the spares dept when I wanted a new one in Tsumeb. IIRC, both are priced the same.....
I fitted mine with the foam on the bottom and the rubber on top to seal onto the lid nicely, however I doubt it makes any real difference
Dungbeetle
Full Name: Rudolf
Home Town: Ellisras
Home Language: Afr
The Guys from Down Under also say - lip seal at the bottom......
https://www.patrol4x4.com/threads/30crd ... st-7035132
Unkredible
Full Name: Bruce Williamson
Nickname: Unkredible
Home Town: Rivonia
Home Language: E
Has thanked: 27 times
Been thanked: 24 times
Post by Unkredible »
To my mind the lip seal on the bottom makes sense. There is a water drain on the bottom of the filter holder. Lip seal is more likely to keep water on the outside of the filter than the foam...???
285x75x16 MT
DC-DC Charger
That is a distinct pisabolity.... :wink:
Russ Kellermann
Full Name: Russell Kellermann
Nickname: Russell Kellermann
2005 Patrol 4.2TD Wagon
Post by Russ Kellermann »
Rubber Lip seal = bottom
Foam seal = top
I dont think it matters at all.
