Squeaking tyres
Klaus
Full Name: Droppelmann
Nickname: Klaus
Home Town: Kensington, Johannesburg
Current 4x4: Patrol 4.2D GL & Subaru Outback
Home Language: German, English
Has thanked: 1 time
Been thanked: 25 times
Squeaking tyres
Post by Klaus »
The Green Mamba is fitted with BF Goodrich All-Terrain 265/75/16, profile still looking pretty decent. On the last few trips, esp. after the temperatures are not arctic any longer, I noticed quite some squeaking noise on relatively sharp turns. Since neither my driving nor the 4.2D GL are not known for sporty demeanour, I suspect the tyres. I used to have a similar issue with the Yokohama Geolander on the Subaru and was told it’s caused by the rubber mixture.
Or could there be another reason for this?
Re: Squeaking tyres
Are you nor rubbing on your bump stops?
Steele
Full Name: Gareth Steele
Nickname: Steel
Home Town: Jhb
Has thanked: 89 times
Been thanked: 61 times
Re: Squeaking tyres
Post by Steele »
What surface do you notice the squeaking on? Concrete, tar, dirt....?
Cheers, Gareth
Klaus
Nickname: Klaus
Has thanked: 1 time
Re: Squeaking tyres
Post by Klaus »
Sorry Tinus, what do you mean by bump stops?
Steele, it is on normal tar, esp. on these little round abouts, tight turns in slow speed.
Craig Lord
Full Name: Craig Lord
Nickname: Craig
Home Town: Tuli Block
Has thanked: 97 times
Been thanked: 60 times
Re: Squeaking tyres
Post by Craig Lord »
My BFG KO2s squeak on some smooth concrete surfaces such as in underground car parks especially on tight turns if the ambient temp is high. They dont make any noise on normal tar though unless the road surface is old and has been worn very smooth, there is one road here that makes them squeak even under braking...
When in doubt throttle out !
4.8 GRX Patrol (sold)
Klaus
Nickname: Klaus
Has thanked: 1 time
Re: Squeaking tyres
Post by Klaus »
Thanks Craig, it's reassuring to know it is caused by the tyres and doesn't indicate anything else.
Also, my wife informed me that the more appropriate term to use is "squealing" not squeaking. Sorry, for that. It appears I'm not a native speaker, yet.
Dungbeetle
Full Name: Rudolf
Nickname: Dungbeetle
Home Town: Ellisras
Home Language: Afr
Been thanked: 69 times
Re: Squeaking tyres
Post by Dungbeetle »
Craig Lord wrote: 27 Aug 2020 06:54 My BFG KO2s squeak on some smooth concrete surfaces such as in underground car parks especially on tight turns if the ambient temp is high. They dont make any noise on normal tar though unless the road surface is old and has been worn very smooth, there is one road here that makes them squeak even under braking...
Ditto here
2012 NP300 DC - platkar
graham1
Full Name: graham robertson
Nickname: graham1
Home Town: Harties
Has thanked: 9 times
Been thanked: 100 times
Re: Squeaking tyres
Post by graham1 »
Its wierd, its almost as if it happens at the change of the seasons, maybe just the right road temperature, and dust layer, I dunno, but yes, just in the past two or three weeks both of mine are squeaking at some roundabouts and corners, the one has bfgs, and the other a mix match of variuos brands.
Klaus
Nickname: Klaus
Has thanked: 1 time
Re: Squeaking tyres
Post by Klaus »
Cool. thanks to everyone for the feedback.
Re: Squeaking tyres
Both my trucks do it... no biggie
Return to “14. Rims & Tyres”
