Hey Chaps
Would these be any good on a GU TD42?
https://www.fundityres.co.za/235-85r16- ... r-114-111q
Currently has Conti Contact 4x4 245/70R16 but they are almost finished and looks a bit small diameter wise
Paul
GU Pickup - tyres on OEM steel rims
- Been thanked: 1036 times
Re: GU Pickup - tyres on OEM steel rims
Can't comment on the brand or specific tire model.
With regard to the size, you are currently on 30.5" tires. The size you are looking at is 31.5", so a little better. Personally, I think Patrols should be on at least 33's.
Do those come in 255/85R16?
- Steele
- Full Name: Gareth Steele
- Nickname: Steel
- Home Town: Jhb
- Has thanked: 89 times
- Been thanked: 61 times
The tyres in your link were standard fitment on the last of the LR defenders, so apart from leaking oil, they are probably pretty decent. I'm not sure about the 4.2 N/A as I have the 3.0crd but I have just fitted 33's on mine and it is a big improvement.
Cheers, Gareth
4.2 td turns 35 very nice ...ask Leon and Graham R they both went to 35 and are very happy
