GL bolt holes?
Steele
Full Name: Gareth Steele
Nickname: Steel
Home Town: Jhb
Has thanked: 90 times
Been thanked: 62 times
GL bolt holes?
Post by Steele »
Hi all, does anyone know if the GL (5 seater) has the bolt holes in the back on the wheel arches for attaching the 7 seats? I want to use these for the drawers system I'm planning.
Thought I would ask before I pull off the wheel arch lining and break something :rolling:
Cheers, Gareth
Re: GL bolt holes?
On the GQ, all I have on wheel arch are the anchors for the 3rd row seat safety belts
Re: GL bolt holes?
The GU GRX's have two threaded holes in the body work on either wheel arch where the third row seat hinges attach. There are also two clasps on the floor (2 bolts per clasp) where the seat locking mechanism clicks in.
Oetie
Full Name: Leon Fouche
Nickname: Oetie
Has thanked: 394 times
Been thanked: 141 times
Re: GL bolt holes?
Post by Oetie »
Steele wrote: 29 Jul 2020 10:50 Hi all, does anyone know if the GL (5 seater) has the bolt holes in the back on the wheel arches for attaching the 7 seats? I want to use these for the drawers system I'm planning.
No bolt holes on the wheel arches, I actually cut a piece of the plastic cover open to see if there are any.
ORRA - L65
HAM - ZS6LEF
Tlou - 2009 Patrol TD42T
Steele
Nickname: Steel
Home Town: Jhb
Re: GL bolt holes?
Post by Steele »
Aah that is disappointing, would have been the perfect position for what I wanted to do. :doh:
Cheers, Gareth
Oetie
Nickname: Oetie
Re: GL bolt holes?
Post by Oetie »
Steele wrote: 29 Jul 2020 15:42 Aah that is disappointing, would have been the perfect position for what I wanted to do. :doh:
Nothing stopping you from drilling a hole and insert a rivnut for what you want to do.
ORRA - L65
HAM - ZS6LEF
Steele
Nickname: Steel
Home Town: Jhb
Re: GL bolt holes?
Post by Steele »
Yeah just much easier if it is already there. Wanted to mount the shelf for my dual battery and the seat mounting points are already nice and strong. Will strip away the lining and check the options.
Cheers, Gareth
Oetie
Nickname: Oetie
Re: GL bolt holes?
Post by Oetie »
Steele wrote:Yeah just much easier if it is already there. Wanted to mount the shelf for my dual battery and the seat mounting points are already nice and strong. Will strip away the lining and check the options.
Removing of side lining is not a big issue on the GL, start at the top lining and work your way down, quick work.
Sent from my iPhone using Tapatalk
ORRA - L65
HAM - ZS6LEF
