4.2 Project
dapper
Junior Member
Junior Member
Full Name: Pieter van der merwe
Nickname: Dapper
Home Town: Vyeboom
Current 4x4: hilux 2.7
Home Language: afrikaans
4.2 Project
Post by dapper »
Will you be able to fit 35' tyres on the 4.2 models,what are the cons of these vehicles,what about performance and how much should you pay for them.
tour de frans
Been thanked: 22 times
Re: 4.2 Project
Post by tour de frans »
Yes,with a suspetion lift it will fit.the performsnce will be worse than normal.You will pay about R3000 per tyre,for a proper one.
Gu y61 wagon- 6.0L chevy
Gu y61 pickup- 6.2L chevy
Russ Kellermann
Full Name: Russell Kellermann
Nickname: Russell Kellermann
2005 Patrol 4.2TD Wagon
Re: 4.2 Project
Post by Russ Kellermann »
Personally ,
If i was going to fit 35's to my 4.2 i'd change the Diff ratio's. and, naturally, suspension lift for clearance. If its the 4.2D you got, like mine, then i doubt weather the thing will even move with 35's on it. :mytwocents:
tour de frans
Re: 4.2 Project
Hi Russ
Yes we have the same enjine,only mine is turbo.I run with 33' tyres and it will go strong with the 35'.(I am not sure now,are your 4.2 turbo?And if so is it factory or aftermarket?)
Russ Kellermann
Re: 4.2 Project
haha, negative , im a normally aspirated 4.2 , no turbos for me again. Should be way easier to turn those 35's with that extra bit of forced induction. Re your actual question - If you can fit them on 4.5 and 4.8 , then there's no reason you cant fir them on a 4.2. (yours is a wagon right ? not the pickup like mine?)
dapper
Junior Member
Junior Member
Nickname: Dapper
Home Town: Vyeboom
Re: 4.2 Project
Post by dapper »
I still have to buy a vehicle,that is why i am asking,i do have a set of 35 tyres but should i rather sell them or will the patrol survive with them,i do own a immaculate 1963 g60 with 27 000 miles,everythig still original,will fill in that new member questionnaire if i can move it to where it must be.
tour de frans
Re: 4.2 Project
Yes Russ,I have a wagon,and thinking of 35' with my next tire change.I have to think of that because 35' are to big for road use,I am not allways in the bush.Why not turbo again?
Dapper, 35's look right on a Patrol and they will work good with the heavy car.If you own a 4.2 non turbo the car will suffer even with 33's.O welcome to the forum,and show us some Pics.
Rdgs
Russ Kellermann
Re: 4.2 Project
i agree with the above comment. Diff ratio changes for boys with Diesel Trolls!!! :helpsign: hahaha
ChristoSlang
Nickname: ChristoSlang
Home Town: Pretoria, ZA
Has thanked: 27 times
Been thanked: 136 times
Re: 4.2 Project
Post by ChristoSlang »
I must concur with the advice...
My vehicle runs on 33" MTs and has a turbo. I can only imagine how tedious the going would be without a turbo to help things along!
For a mixed use vehicle I won't go over 33'"...
Christo (the snake man)
Werf Otter
Junior Member
Junior Member
Full Name: Jacques Odendal
Nickname: Werf Otter
Home Town: Robertson W/C
Current 4x4: 2007 Patrol 4.2 D P/U
Re: 4.2 Project
Post by Werf Otter »
35" werk met n "lift" maar vergeet van 5de gear.
