16 inch mag rim for 2002 Patrol
Franc
Full Name: Francois Smit
Nickname: Francois
Home Town: Port Elizabeth
Current 4x4: Nissan Patrol 4.5 GL
Has thanked: 7 times
Post by Franc »
I’m looking for 16 inch mag rim to replace damaged spare wheel rim.
Will highly appreciate if anyone has one available. :thumbup:
mvcoller
Full Name: Malcolm van Coller
Nickname: mvcoller
1998 4.5 Patrol SGL
Home Language: Afr & Eng
Has thanked: 41 times
Been thanked: 187 times
Re: 16 inch mag rim for 2002 Patrol
Post by mvcoller »
Have you considered having it repaired. It may be quicker and much easier than to find just one mag wheel.
I have seen them repair some and had some of my own really badly damaged rims welded and machined back to original. And no need to doubt stregth of repaired aloy wheels, I raced on repaired wheels without them cracking or breaking....
Franc
Nickname: Francois
Post by Franc »
Thank you Malcolm, I will take it to Rimrite here in PE. The mag was cut with a angle grinder. I am assuming that a previous owner had lost the key to a “locknut” and had no choice but te cut the rim to get it off the spare wheel holder, so the damage is a bit of a safety issue. Hopefully it can be repaired.
Thanks again for your suggestion. :thumbup:
