Tb45 Distributor
- Junior Member
- Full Name: Herman Louw
- Nickname: Harry
- Home Town: Hennenman
- Current 4x4: 2000 Nissan Patrol 4.5 GRX
- Been thanked: 1 time
Tb45 Distributor
Hi All
As my 4.5 went over the 316 000km mark yesterday and from what I have heard and read the distributor on the 4.5 has the tendency to give problems from around 300 000km, I would just what to find out what the way forward is.
To just replace it when it fails or is the a upgrade of some sort that can be done?
I do have a ping when under load at about 3000rpm and that happens everytime I go over Van Reenens pass. Otherwise there is no major issues to indicate that the distributor has reached the end of its life.
Can't wait for your inputs
Thanks alot
Thanks alot
Re: Tb45 Distributor
wear on 4.5 distributor is a problem because there is no other timing correction mabe speak to dawid or order one online ?
- Full Name: Pieter Botha
- Nickname: Pieter
- Home Town: Alberton
- Has thanked: 6 times
- Been thanked: 97 times
Over the years I have seen advertising for distributor recon centres. Perhaps google that and try one if these places
- Full Name: Anthony Forgey
- Nickname: Anthony
- Home Town: Randburg
- Has thanked: 179 times
- Been thanked: 206 times
change out the points for electronic ignition
- Junior Member
- Nickname: Harry
I also thought about it, but didn't know if it is possible. Is that a big story and what would all need to be done. Who will be able to do it?
- Has thanked: 1136 times
- Been thanked: 1047 times
TB45 has electronic ignition already.
- Nickname: Anthony
my bad, somehow my brain read tb42
- David M
- Full Name: David Marais
- Nickname: David Marais
- Home Town: Midrand
- Has thanked: 20 times
You can have the shaft etc reconditioned but unfortunately the coil pack is tired and no replacement available in SA.
Last time I checked replacement distributor was over R 14 k from Nissan.
There is a coil pack replacement available from Auto Parts Supply in Australia for 90 Aussie dollars but they do not ship to SA.
What I have never investigated and may be worth looking at is Spitronics or similar. I am however not a fan of aftermarket electronics but it seems to be improving.
- Junior Member
- Nickname: Harry
Thanks all for you inputs.
So basically it is either recon, replace or go with aftermarket management.
I am scared to go with the aftermarket management but will look into it.
thys ellis knows his stuff but sure you can get a working dizzy from david or order one online partsouq .com
