Electric Seat not going backwards
- Full Name: graham robertson
- Nickname: graham1
- Home Town: Harties
- Has thanked: 9 times
- Been thanked: 100 times
Hi Guys,
Has anyone had this issue before - my electric passenger seat doesn't want to go backwards, it moves forward, and the backrest moves in both directions, but it wont go back.
Im guessing its a switch issue, but me and electronics just dont mix, I dont understand that magic voodoo stuff. If anyone has had this issue I would be greatly appreciative to hear how to fix it.
Thanks!
Thanks!
- Full Name: Craig Lord
- Nickname: Craig
- Home Town: Tuli Block
- Has thanked: 97 times
- Been thanked: 60 times
Re: Electric Seat not going backwards
There is probably a carbon buildup or something dirty on that contact point. It happens with the switches for my passenger windows every now and again. Might just need a good clean. I'm not sure how to disassemble and reassemble that switch though... if it's anything like the window switches they are full of small parts that like to go everywhere when you take them apart
If you get the unit out make sure you take it apart in an oven tray or something to contain anything that might get lost while you do it. I'm sure in the workshop manual there is instructions on how to do this.
When in doubt throttle out !
4.8 GRX Patrol (sold)
- JohnBoyZA
- Site Admin
- Full Name: John Murray
- Nickname: John Boy
- Home Town: Bloubergstrand
- Current 4x4: Patrol GRX 4.8
- Has thanked: 1046 times
- Been thanked: 231 times
Hi Graham
common problem, happened to me ... tried cleaning (As Craig says, tricky business)
I eventually got a brand new driver-side one from Marinus via Dubai, but could only get the one side at the time. I then got a second hand one for passenger-side one from Dawid V. Both gave excellent service.
viewtopic.php?f=48&t=7939
Good luck
John
Good luck
John
- Nickname: graham1
Aha. Ok, thanks very much for that info John!
Maybe I must see if Ant can tackle it. I’m not spending R2500 on a switch like Tinus said in that other thread though! I’ll rather just chuck in a manual seat then i reckon
- Rhett
- Nickname: Rhett
- Home Town: Heidelberg
- Has thanked: 163 times
- Been thanked: 78 times
Ja I was having the same issue, but the gremlin seems to have disappeared for now as it's working again.
Rhett
Nissan Patrol 4.8 GRX
Toyota Land Cruiser HJ45
- JohnBoyZA
- Site Admin
- Rhett
- Nickname: Rhett
Rhett
- JohnBoyZA
- Site Admin
Lol, sorry man, hope it stays as is, it's just mine was intermittent then finally stopped completely ...
Graham, please keep us updated, thanx
- Rhett
- Nickname: Rhett
Haha well let's hope it still works for a while. Not often I need to move the seat position.
Do the Patrol's not share this electric mechanism with another Nissan vehicle? It's not that often that they produce parts specifically for one model, specifically switches and such
Rhett
- Full Name: Anthony Forgey
- Nickname: Anthony
- Home Town: Randburg
- Has thanked: 182 times
- Been thanked: 206 times
There's pretty much two possibilities:
1. the switch contacts have built up some corrosion and no longer make clean contact
or
2. the one motor is poked.
You definitely want option 1 to be the problem because option 2 is not cheap at all.
I've taken a few of these switches apart, cleaned with Wurth Contact OL then spray with Wurth contact cleaner once clean. Then a bit of assembly grease (vaseline will do) then put it all together and it has a new life.
There is no info in the workshop manual on doing this because its not supposed to be a serviceable part. It is a bugger to do, but it can be done.
or
