JTEC
Posts: 172 Joined: 04 May 2019 14:08
Full Name: Jade Dafel
Nickname: JTEC
Home Town: Somerset West
Has thanked: 164 times
Been thanked: 64 times
Post
by JTEC » 05 Dec 2019 09:01
Guys does anyone know or could possibly measure the length of the bolts that hold the factory recovery point at the rear? I got an upgraded recovery point from Tinus but I want to make sure the bolts are the correct length. Thanks
Posts: 6160 Joined: 10 Sep 2010 07:21
Has thanked: 1134 times
Been thanked: 1046 times
Post
by Peter Connan » 05 Dec 2019 11:54
You need at least 20mm going into the chassis, so (assuming the plate is 12mm thick) anything from 35mm on will work.
There is a lot of space there, so you can use bolts that are considerably too long without issues.
I would go for 40-50mm.
JTEC
Nickname: JTEC
Post
by JTEC » 05 Dec 2019 13:56
Peter Connan wrote: ↑ 05 Dec 2019 11:54
Excellent thanks Peter
Posts: 2053 Joined: 21 Oct 2014 21:01
Current 4x4: THE PATROL COLLECTION 2004 4.8 GRX TURBO "Tinkerbell" 2003 TD42T GRX "The Coal Roller"
Has thanked: 211 times
Been thanked: 218 times
Post
by hugejp » 05 Dec 2019 14:51
Pls just check those threads, if memory serves they used a very fine thread... only remember it taking forever to turn them out
Sweetlips
Posts: 227 Joined: 02 Jun 2011 16:12
Full Name: Lawrence
Nickname: Sweetlips
Home Town: Paarl
Current 4x4: 2006 4.8 GRX
Has thanked: 47 times
Been thanked: 99 times
Post
by Sweetlips » 05 Dec 2019 20:38
Jade post a pic once you done.
Post
by Peter Connan » 06 Dec 2019 04:49
hugejp wrote: ↑ 05 Dec 2019 14:51
Indeed they are. But I can't remember which thread pitch. I think M10 x 1.25, but I am not sure.
JTEC
Nickname: JTEC
Post
by JTEC » 06 Dec 2019 07:10
Thanks guys, local bolt supplier should allow me to test the thread so I willl double check and confirm.
Will do Lawrence
