I picked up this error code when I put the ECU in diagnostic mode.
From an interwebs source I get the following.
"U1000 Nissan Tech Notes
Usually, the problem is poor harness ground connection."
"Service bulletin suggests cleaning engine and body harness ground connection to repair the problem.
- Clean/re-tighten ECM ground connections.
- Clean/re-tighten negative battery cable body connection and battery post connection.
- If needed, clean and ensure good contact between the steering member assembly and the left side instrument stay assembly."
Where is said harness that I must clean and which ground connections should I be looking at? Any ideas?
U1000 error code
- nisjeep
- Full Name: Peter Church
- Nickname: Nisjeep
- Home Town: Vredenburg
- Current 4x4: 1995 Patrol GQ SGL
2001 Terrano 2 - Home Language: Afrikaans
- Has thanked: 5 times
- Been thanked: 14 times
Re: U1000 error code
That location refers to the earth cluster on the steering column . In our case on the right side.
There's another earth cluster by either kick panel. Nissan loves the multiple earth clusters.
Saying that , You can never have enough earths.
So start at battery (Nissan clamps are shit) and work your way to the engine , body clusters and through to the
under dash clusters. Clean with emery paper and put a suitable grease (I prefer coppaslip) and tighten them down.
You a re still lucky , because you can read the code . Did you mess around with the battery by any chance?
Good luck
Good luck
- Full Name: Paul Greeff
- Nickname: Paul
- Has thanked: 24 times
- Been thanked: 56 times
Its an intermittent fault.
I picked it up the first time last year, so I thought I should try and sort it out. Most of the niggles on my van have been rectified, this one still irks me.
2004 Nissan Patrol 4.8
